QUICK HELP! What doe this hole do in Throttle Body?
QUICK HELP! What does this hole do in Throttle Body?
I'm still sorting my surging idle after a 09 manifold swap. If I plug the hole on the upper left in side of the stock throttle body, it idles PERFECT!!!
What does this hole on the upper left inside the tb do? Its not the IACV port on the bottom.
If plugging this hole makes my idle perfect, what is this telling me I need to fix? Surely this hole is here for a reason....
Turns out it is part of the idle air circuit. The screw ontop of the TB facing you as you look into the TB adjusts how much air is let past it.
The reason mine was pulling so much air into it was because the lousy P2R thermal gasket in conjunction with their 09 manifold spacer was not sealing on this circuit on the backside of the TB causing yet another vacuum leak.....
I'll add this to my "How to get a P2R adapter to actually work" thread...
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
