Questions about iVTEC
1. Is the continuously variable nature of iVTEC going to take away our patented VTEC growl at changover? Will the engine note just continue to spool up gradually until redline?
2. What engine will get iVTEC next? Can iVTEC be adapted to the current generation of engines (ie new CL/TL).
3. What would iVTEC do to our engine if it were present? Higher overall power, greater torque band, more low end grunt?
What do you guys think? I think this will be a good way to introduce our new cousin and begin to understand this thing a little bit more.
Black/black CLS
Comptech headers, springs, swaybars
Koni yellows
Polarg M6 road lamps
Solaris Hi beams
Potenza RE730 225/45/17
Red AEM CAI
Denso Iridium plugs
35% metallic tint
Black/black CLS
Koni yellows
Solaris Hi beams
Red AEM CAI
Denso Iridium plugs
35% metallic tint
<font face="Verdana, Arial" size="2">Originally posted by JZ:
1. Is the continuously variable nature of iVTEC going to take away our patented VTEC growl at changover? Will the engine note just continue to spool up gradually until redline?</font>
2. What engine will get iVTEC next? Can iVTEC be adapted to the current generation of engines (ie new CL/TL).</font>
3. What would iVTEC do to our engine if it were present? Higher overall power, greater torque band, more low end grunt?</font>
051/LP/SR/LD/HH
Potenza S-02 Pole Position
The Reasonable Voice of Bias
I'm reading from the new Acura magazine and it states the iVTEC, "provides continuously variable camshaft timing to broaden the power band, boost fuel efficiency and lower emissions". Is that not infinitely variable?
I guess some of that quote answered my own questions!! Talk about reading comprehension!!)
Black/black CLS
Koni yellows
Solaris Hi beams
Red AEM CAI
Denso Iridium plugs
35% metallic tint
Black/black CLS
Koni yellows
Solaris Hi beams
Red AEM CAI
Denso Iridium plugs
35% metallic tint
I'm reading from the new Acura magazine and it states the iVTEC, "provides continuously variable camshaft timing to broaden the power band, boost fuel efficiency and lower emissions". Is that not infinitely variable?</font>
Valve lift and duration, which results from switching from the low-rpm cam profile to the high-rpm cam profile, is partly responsible for the characteristic VTEC "growl", not the continuously variable cam timing. (Switching to the short manifold tract is the other part responsible for the "growl".)
051/LP/SR/LD/HH
continuous != infinite.
Technically, you could continuously switch between two settings. That would hardly be infinite settings.
-J
2001 CL-S Aegean Blue/black interior spoiler, wheel locks, no-navi
50% tint sides, 35% back.
J&J custom CAI
Comptech drop-in filter.
I smell Comptech springs and sways in the near future! w00t!
-J
J&J custom CAI
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
