Question for those with TL Stock Fog Switch
I'm working on a fog light install that I'll write up a DIY with pics, but how in the world did you wire anything up to that switch? The pins are so close together and deep in the socket.. is it possible to get just the harness that plugs into the switch?
Pic for reference:
Pic for reference:
You go to a junkyard and cut out the cable leading TO that switch, or buy the appropriate harness that has the connector connecting to the switch. That would make for the cleanest install. Otherwise, use a very fine tip soldering iron and TRY to solder into that switch directly... (this would be much more difficult).
I'm gonna try trimming down a butt connector:
And hope I can make a single pin crimp on connector.
If that doesn't work I'm probably gonna have to take the dremel to the socket housing to expose the pins and then solder onto them with some heatshrink for insulation.. should be fuuun.
Whats up with RDX owners?
I bought the sub harness. Its $15, but worth it for the connector IMO.
sockr1
10-01-2015 01:31 AM
Skirmich
09-15-2015 06:41 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
