Question about the stock alarm
I noticed my friend's CLS that when he locked it, it had a chirp and i thought that it was aftermarket or something but he tells me its stock.
I remmeber someone posting here that there is a way to turn on/off the chirp becuz mine doens't chirp and i want it to.
Can someone help me out?
Retired. Not available.
Originally posted by QwiQ cLs:
<STRONG>Yeah man
everything is closed of course
all doors and trunks
i still don't get why!!</STRONG>
<STRONG>Yeah man
Originally posted by Norcal CL-s:
<STRONG>QwiQ cLs,
Look at your owners manual, theirs a section on turning ON and Off your chirp. I personally didn't like the chirp so i turned mine off..</STRONG>
<STRONG>QwiQ cLs,
Really/?????
gosh i never knew that! i'll go try that later
g thanks guys
ok
the only thing i found on the manual is that they say it will beep within 5 seconds of pressing it another time. but then i tried it tons of times with both keys and it didn;t work!!
Someone said that it tells u how to turn the chirp on and off on the manual ! Can you pls tell me the exact page number and under wut category??? thanks much appreciated!
Moderator Alumnus
Okay, I looked in my manual, and didn't find any instructions on how to turn off the alarm beep. Is this guy pulling my leg or am I missing something?
Helms manual owners, speak up!
I looked through it and saw nothing about turning on/off the alarm chirp. I did learn a different trick though: normally, the seat returns to the memory setting corresponding to the remote used (1 or 2) but the manual explains that this feature can be disabled (so the seat remains in it's current position). To turn the feature off, press the Lock and Unlock button on the remote at the same time until the LED on the remote blinks twice. To turn it back on, hold both buttons until it blinks once. I tried it and it works. This may be common knowledge to some but it was new for me...
Also, the manual lists a way to test the alarm chirp: remove right inner fender, disconnect the two-prong connector going into the buzzer (it looks like a small cylinder), connect battery power to #2 terminal of connector (the right side when connector prong is on top), ground #1 terminal. It should chirp. If it doesn't, it says to remove the two screws and replace unit.
aka gimmesomesugar
QuiQ cLs, I told you at the Revscene meet...save yourself the "head-scratching" and just wait till your next service visit. Get them to fix it for you when you bring your car in.
