Question...?
Question...?
Ok I'm sure this is a repost so I'll just let you all know that right now but I'm way too lazy to go through every thread that came up in the search... That being said, I remember reading somewhere that '03 CL-S doesnt have a rear camber adj.
The thing thats confusing me right now is I found one from SPC Performance. It can be adjusted from -2.00 to +4.00
Please correct me if I'm wrong but I'm trying to do as much suspension research as I can because I'm looking to lower the car sooner than later.
You are correct... the CL/TL is not adjustable in the rear for camber... you need a camber kit. The one you mentioned should be more then enough to correct your camber after you lower the car.
I needed a camber kit as well after lowering the car. Once I had it installed, the dealer adjusted it and all is now well with my camber
Thanks, but I still swear I saw a thread here recently about there not being a camber kit available for the rear. I mean I've heard of that before because when I slammed my GTI I got the camber kit for the front but there wasn't one for the rear. I dont know maybe I'm hallucinating ... those damn acid flashbacks
![Screwy](https://acurazine.com/forums/images/smilies/screwy.gif)
