projector fog light question
i got my projector fogs in, but i noticed they had a small label that said "top"...so im assuming that would be the side facing upwards.... but for some odd reason, the metal light reflector inside the fogs would be at the bottom...meaning the light will reflect upwards??? doesnt make any sense?.....
can someone let me know where the metal light relfectors should be inside of the fogs? top or bottom? thanks
PICS WILL BE NICE
yup got them all (new fogs + inserts), i used the rotary tool to cut a hole in the inserts, and trust me, it was a time consuming process...the fog light size did not help either..i thought these new ones would be smaller in height..not by much... i will post photos of the new ones with them fitted into the inserts when i get off work.
ok, another question for who might know... the hole that i cut into the inserts isnt perfect, theres some spacing between the light and the hole ( i basically cut it a bit bigger then i needed), so is there a way i can get some type of black instant epoxy or something to cover the slit?
i will post the pics in my original foglights thread that i started a while back. this one was just to ask about the fog light directions.
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
