Progress RSB (04-08 TL) on CL-S
Uses turn signals in my
I had my friend help me install the Progress adjustable RSB this afternoon. Install was pretty straightforward and took about thirty mins, only thing that was somewhat tricky was removing where the endlinks connected to the RSB. We set it on the sport setting.
Took it for a drive and the steering was more responsive and the handling felt a little more secure, can't wait to test it out when I get new/better tires.
Progress 24 mm adjustable RSB (04-08 TL) vs OEM.
The Progress has a sport and soft setting, came with all new hardware and a small tube of grease. There hasn't been any squeeking so far.
i just upgraded my rsb to a 22mm comptech on my accord and it feels VERY different. alot more neutral. The front end of the car and rear work together now when before the back end was sloppy
Originally Posted by poisx7
do u think its something i cud install mysef ?????
Do u think its advisable if u car is on a air ride, pls let me know.
Originally Posted by CleanCL
always wanted to install this bar... i recommend upgrading the sway bar bushings and brackets.
White as night.
Originally Posted by Excelerate
This will basically help reduce body roll. The bar is a 24mm adjustable rear sway bar. The setting closest to the front of the car is the softer setting. Basically it will help reduce understeer or plowing (common on FWD cars).
Originally Posted by Corrosion
Do you sell something like this?
'03 ABP YA4-S 6MT
good deal!
Originally Posted by TCM 01 CL-S
I agree. I am going to try to upgrade to the moog endlinks sometime in the future, the factory ones seemed decently worn. Any idea if that would make much of a difference?
but i've read NAPA actually has better construction stuff than moog. check it out.
Blown is Best
i replaced all of my endlinks and balljoints with moog... it just had a slightly tighter steering response.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
