Problem with Stock CD Player
It's Always Shabbat
All,
My stock CD player (01 CLS) no longer feeds or ejects cds. I hit 'LOAD', wait for the LCD to flash 'LOAD, and then when I stick the CD in, it doesn't take.
Trying to get my CDs out (ones that are already in), the LCD flashes 'ErrE1' or something like that (I can find out pretty easily by going to my car).
Any ideas how to fix this?
Thanks for the help,
-Elliot
-Elliot
It's Always Shabbat
Oh, and by the way -- a new 6 disc in-dash costs $804. So, please, please, try to help me :-) It'll easily be over $1000 with labor -- this is ridiculous.
-Elliot
-Elliot
It's Always Shabbat
Originally Posted by kevin79925
get a new one?
Please be realistic.
I now drive an accord....
get a new one?
Take it to the dealer and let them open it up, or if you want a new CD player take this on out and smash till your CD"s are visable
Edit: Screw getting a new 6 disc changer, just get an aftermarket unit with MP3 capability. You can get ~10 discs on 1 in MP3 format for under 300
It's Always Shabbat
Originally Posted by spdy0001
I think he wants to know how to get his CD's out.
Actually, I have all my discs out. I got them out by sticking a thin pencil in and tilting the disc downward while hitting eject. But now I'd like to fix the player so I can seemlessly insert and eject cds, like it used to be operate.
Perhaps a way to lubricate or clean the mechanism that loads/ejects the discs?
I'm here in spirit...
Did you put CD-R'd with lables in it?? I did, it got stuck. I notice that it doesn't seem to work as good as it used to since then. That's ok with me though cause I'd like to put a DVD/Navi unit in there eventually.
It's Always Shabbat
Nope -- I've put CD-Rs in there, but none with labels. Literally, none.
Good thought.
Elliot, I think the reason why everyone is posting "just get another deck," weather a factory one or not, is that these issues are not commonlyn solved by doing a bit of labor on the existing unit.
If you were to take it in to a dealer to have it fixed, they'd charge your the price of a new unit.
Here the best suggestion I can give you: take the device our of your car, and bring it to a specialized electronics repair shop... preferably an authorized Bose dealer. Ask them if they can fix it. If that doesn't work, you may have to bite the bullet and replace the unit. Good luck man!
I need FI
same thing is currently happening to me. I hit it a couple of times to make the cd's come out and it used to work like a charm, but now, nothing works except the am/fm radio and tape deck
Some of you guys need to realize that replacing the factory cd player with an aftermarket unit will actually hurt the resale value of our cars. What do you think happens to the volume up/down and skip buttons on the streering wheel?
Not only that, but it will make it tougher to sell the car because you have to sell it to someone who doesn't mind having an aftermarket deck, which looks significantly out of place in comparison to the factory unit that blends into the interior of the car seemlessly.
I wouldn't have bought my car w/o the factory system even if it had some kind of fancy ass 1000$ MP3 player in its place.
It's Always Shabbat
I agree 03 CLTypeS. After market, unless done "right", does not look as good. The unit is relatively large (larger than a new headunit at Best Buy, for example) and so replacing it with a different unit is unacceptable.
I'd like to have my current unit work properly -- just wish I knew what had to be done. This is so frustrating.
Patriots Fan for Life
-Elliot
-Elliot
All,
-Elliot
-Elliot
Originally Posted by goredcar
This is a common problem... do a search. I had this same issue and it is software related. Certain compinations of things can "reset" it. My dealer was useless and wanted to sell me a reconditioned unit. The trick that worked for me most of the time was power up the unit while holding the eject button. Others have had success with other approached. Do a search!
also, alternating load and eject buttons while going from ACC to Ignition with the key works sometimes. I don't use label CDs, only blank CD-Rs.
Leaving one CD spot empty helps at times, but it does seem kinda random.
I would only replace it with OEM if I plan to sell car soon. If you are planing to keep your car for a very long time, it does not matter much if you have a stock unit or after market. I am sure you can put something after market that looks nice and fits well.
I just traded in my Accord and it had an aftermarket deck in it which left the steering wheel controls useless and it didn't hurt my trade in value at all. So it's just up to you and what your taste is.
FWD tuna boat
i cannot live without the steering wheel controls.
Out of all the cars I've owned (and it's been a bunch), If I replaced the HU, I have always put the factory deck back IN the car before trading it in or selling it except once. The one time I didn't was my Suby Impreza. I left a Sony MD player HU w/ 10 cd changer in it because they told me they'd give me $500 more for the car if I did. I say if you need to replace it go aftermarket but keep it clean (don't cut shit up) so you can put it back if need be. On the other hand, I do tend to agree with 03 CL typeS regarding looks. OEM looks much better 9 out of 10 times. However, it will, in no way, hurt your resale.
I don't know about your loading problem but I know if you burn your own Cd's and make a label for them then try to use them in your CL changer, they may not come out or jam in their.
I loaded a few home made ones with labels and the player would moan and groan for a while then either give me the same error code or eject them. Since that experience, no more CD's with home made labels stuck on them go in that changer cause they may not come out.
snorf
11-04-2019 06:44 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
Abe_Froman
09-16-2015 01:27 PM
ivegotthenav
09-11-2015 07:51 PM
