Pre-Race Burnout n00b question
I searched extensively through the FAQs before posting this, but here goes...
I've never been to the track to race personally but the more I read here the more I want to. A good friend of mine used to race a lot of cars in his day and told me a bunch of "tips" including a pre-race burnout to get the tires warm.
Well, the question I have quite simply is what's the easiest way to do this w/o killin your car? Yeah, can put it up to 5k and dump the clutch, but I have to drive this every day for a few years. I don't wanna go out to a parking lot and start lighting them up (even if it's fun) until I have some thoughts from people w/ a little more experience on the track.
Also, we let the air out of the tires and replaced with pure nitrogen. He said this gets rid of most of the water vapor in the tires and so the pressure won't change as much when the tires go through the cooling cycles (ie. when you burnout). Can anyone confirm this helps? The car sure handles differently now.
Thanks for all the tips on launches and improving times... See you at the track.
-- Nihil
-- Nihil
for cars like ours, that pre-run burnout is pointless...the only vehicles that benefit from that are the suped up muscle cars with hoosier or mickey thompson slick racing tires....street tires dont need that and all you are doing is wasting your tread
im back
on the contrary my 1st run was a 15.1 when my nitto's were cold....then i ran a 14.4 2 runs later when they were nice and hot because i yanked the ebrake and roasted em(when my ebrake was strong enough to hold the car in place now my car just pulls)
other factors would have caused the time difference...not the heat of the tires....
i.e.
sloppy shifting
lousy traction regardless of tire heat
track conditions
temp of coolant
air temp
your driving ability
etc
i.e.
sloppy shifting
track conditions
temp of coolant
air temp
etc
im back
nooo, because when they were cold i spun halfway down the track(doing all 3 of the same launches at 1600 rpm's), then after that they warmed up a lil bit spun a little bit my 2nd run and then my 3rd run when i roasted them to get them nice and hot, i hopped a lil then gripped, not spun. the heat does matter
My best results on street radials was with a quick spin to clean the tires of any rocks, dirt or water, not a "burnout". Street radials will become greasy if you really heat them up.
thank you pull T....some people just dont understand the real reason for the burnout box at the track..
rob, there were most definately other factors involved in your experiences between runs having nothing to do with your tires temp..but due to your own associative reasoning, you associate your better traction on run #2 with the fact that you did a silly burnout before the run, however, it is highly doubtful that your burnout did anything besides waste some of your tread for no reason. maybe on your first run you drove right through the burnout area and got the water and stuff all over your front tires, that would cause your crappy traction.....
im back
also pull-t you have the 555R's, i have the model right below now you know your 555R's wont grip right unless you heat them up, believe it or not the 555's are the same way, they grip better when warmed up.
You got better results from really heating them up, so continue to do so, I was just relaying what worked for me and in my experience what has worked best for others. Exp[erimentation is key though and everyone's results can vary.
im back
exactly i'll stick with what worked for me and if you had the quick spin and those worked better for you then stick with that. It also varies on the tire, i know a bunch of my friends have the toyo t1-s and they have to heat them up to get them to stick well also. your right, experimenting is key
Thanks for saving me a few inches of tread. When I finally get out there I'll just do as you said and experiment a bit. There are gonna be so many variables (including adrenaline) I'm afraid I might pull high 15s.
What about the nitrogen in the tires?
-- Nihil
-- Nihil
Selling Chicken Parts
been through both methods with the 555Rs and I gotta say that I was wasting rubber doing burnouts. Lowering pressure helped, but not burnouts.
don't let the pressure out of regular stock tires...the sidewalls are too stiff, you'll just bring the center of the tire off of the ground.
drive around the water, you'll only tack water onto the starting line.
I was pulling 2.0 60 fts on regular old goodyears before i got the Nittos...now my problem is boggin, i'm still trying to sort the thing out, i'm still not used to cars with no low end torque...
Who Needs a Type-S?
You might want to run high pressure in your rears to try and combat squat.
If the starting area has a good dose of rubber and VHT, excessive spinning of your tires will cause little pieces of rubber to adhere to your tread blocks which will RUIN traction...with Toyo T1-S a quick spin to get rid of gunk (they are a sticky tire after all) and it will warm them enough. My friend with a CL-S also robbed my stock Accord LX 15" steelies and uses those on his rear...
Try and keep your engine as cool as possible, ice on the intake manifold and pipe works wonders, try to keep your engine off until the last possible second, your temp gauage should just be at the first LARGE mark when you line up..
Originally posted by quikcls
ya'll r nuts..you have to do a f in burnout, it totally warms up the tires, prob is your not roastin em long enuf
Who Needs a Type-S?
Originally posted by tuRb0mikEy
you are a moron..please shut up immediately
and for everybody else who doesn't think you need to do a burnout, go outside and smoke the shit outa your tires and then touch them with your fingers and tell me its not hot and sticky!
now here we go again with the caveman educated responses. there is no need for comments like this, very rude and uncivilized! but i'll stoop to your level punk ass! fuck you and your non experienced responses. if you wanna start shit lets fuckin go you bitch! fuck you!
Re: This is how I do a burnout
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
