Power Seat / Driver Memory
Old 09-10-2007, 11:34 AM
It's Always Shabbat
elliot's Avatar
When I try to move the drivers seat either up (towards the steering wheel) or away from the wheel, it only moves a few inches before I have to let go, and do it again to move it even more.. The power just cuts out after a second or two.. Any idea why? Better yet, how do I fix it?
Will doing so make it so when I open the door with the second remote, it'll automatically adjust the seat to the number two position?
Thanks for the help,
Elliot
Old 09-10-2007, 12:21 PM
OG 3.x^7 rawr
SPoolinspOON's Avatar
If you set the memory 1 with the remote, when you use key fob 1, it will have the seat ready to go. Set memory seat 2 with key fob 2 and when using fob2, seat will go to mem2.
Since I am the only one that drives my car and have a mem1 key fob. I set my seating to mem2. Then I set mem 1 almost all the way back. so when I get into the car, im not all bunched up. I hit number 2 on the door and my seat adjusts to what I have it saved.
Old 09-10-2007, 02:08 PM
fuzzy02CLS's Avatar
Same here. I miss the easy entry my 300M had.
Old 09-10-2007, 04:42 PM
It's Always Shabbat
elliot's Avatar
Yes, but I think my battery is depleted such that the seat and mirrors do not adjust.. How do I fix this?
Old 09-10-2007, 05:52 PM
Zippee's Avatar
Replace the battery.
Old 09-10-2007, 06:01 PM
03 Anth Type S 6 Speed
Blasted69's Avatar
would a low battery stop the seat memorizing from working? I have a Key Fob 1 and it can not program memory one. It will just not beep when I press memory then the number 1. I have tried linking and unlinking the fobs to the car but nothing works. Memory two works fine with the second fob.
Any ideas?
Old 09-10-2007, 10:19 PM
Zippee's Avatar
Any ideas?
If you can't program seat 1 inside the car it's not a problem with the remote. If there is enough battery to start the car you have enough to program the seats. Sounds like the problem is in the programing-maybe the switch.
Old 09-10-2007, 10:24 PM
Type S Zero's Avatar
there's a TSB about that issue on MDX (seat moving an inch at a time), you need to replace the front motor position sensor
Old 09-11-2007, 08:27 AM
It's Always Shabbat
elliot's Avatar
Type S Zero,
Any idea where I'd find more information about this? I'd love to get this fixed.
Elliot
Old 09-14-2007, 12:47 AM
Black on Gray all day!
LaZiEx626's Avatar
probably a problem with the battery
rockyboy
08-04-2024 10:35 AM
02-25-2020 09:57 AM
miner
3G RLX (2013+)
36
01-11-2016 04:17 PM
09-14-2015 03:16 PM
Quick Reply: Power Seat / Driver Memory
