Is It Possible Just to Remove Fog Light Housing..??
yes, you can take out the entire fog light housing. There is a screw on the inside side of each housing that you can get to through the lower grille. If you look towards the side of the light, you'll see a half circle cut out of the grille for the screw driver. The screw won't come all the way out, it will just loosen, then there's a clip on the back of the housing that also holds it to the bumper. You can reach it with your hand through the lower grille, and push it up to release it. Hope this makes sense.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
