Polyurethane Vs Fiber Glass
New Question----
---real Difference Between The Two Substance Used To Making A Body Kit. Fiber Glass And Polyeurethane??????----
Not That Polyurethane Is Better Then Fiber, But Some Real Facts Contrasting The Two.
Some Even Say Fiber Glass Can Be Better, Because Its Lighter??
Originally Posted by Acura Cl-P 4 ever
New Question----
Urethane is normally MUCH better than fiberglass with body kits. First off, the urethane bumpers are A LOT more durable than their fiberglass counterparts. If you hit something with it, normally it will pop back into place (kind of like a rubbermaid trash can) and all you have to do is paint it. Fiberglass will actually BREAK and you have to replace the entire bumper. Also, fitment is normally a LOT better since urethane is harder to work with and the companies producing the body kits have put a lot more time and effort into fit and finish. A good fiberglass body kit takes about 10 or so layers to make the bumper (or any body panel) sturdy enough to endure some road abuse---this in turn makes the body kit heavy. Also, most body shops HATE working with fiberglass because the prep time is higher than dealing with a urethane pieces.
The drawback is that urethane body kits cost more- sometimes double the price.
POLY FIBER Material???
Polyfiber kit- the revolutionary new poly fiber combining the best from urethane and fiberglass into one material. These kits have oem like fitment.They also require little to no prep work .
Anyone heard of this new material? What is this about?
Who did this in
Poly-Fiber has actually been used on aircracfts for over 30 years. I don't know of any bodykits that are currently made used poly-fiber, but here is a little info I found (Google is your friend)
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
apr, body, bumper, bumpers, difference, fiber, fiberglass, good, kits, material, poly, polyeurethane, polyurethane, versus, vs
