A-pipe Replacement
A-pipe Replacement
Greetings all...
I've been lurking here for a while absorbing the great info you folks have to share. Now I need a bit of specific information/advice. I tried a search but nothing came up.
I have an '01 CL that the mechanic says has an eraser size hole in the top of the A-pipe.
The shop says that the A-pipe runs about $350 or so and total to do the install would be a bit over $500+ not including replacing the 02 sensor.
I have some friends who have some mad welding skills and I was wondering if it would be worth it to drop the A-pipe assembly and have it welded or just bite the bullet and drop the money on the new assembly?
Is there a Honda crossover part that will work?
Thanks!!!
Mike
Thanks!!!
Mike
cycdaniel
12-17-2019 10:58 AM
Billu99tl
09-13-2015 11:30 AM
