PIAA 19224 road light bulb for my CLS
Since both of my stock road lights are out, I ordred and installed the PIAA 19224 (the white ones, not the yellow ones). Well, here is my problem, apparently the bulbs were pretty big (way bigger than the teeny tiny stock ones), and I had to somewhat jam them through the hole into the housing. Now I am worried about how I am going to get them out if they ever go out *knocking on wood*.
Anyone else has similar worries?
says "hello to my TLX".
those bulbs ARE a tight fit. all i have to say is lubrication. jk
just be careful on the way out whenever and for what reason you have to take them out. if they break, then just try not to get so much of that blue film crap to spread throughout the foglight housing.
SOB type-s
I dropped mine in and they are still bobbing around the road lamp lol. Looks cheesy as hell but im trying to figure out what im doing with the roadlamps anyway!
Acura loyal for 93mo/109k
A medium phillips screw driver will back the screw out enough to where you can reach inside the lower grill area and push the housing out from behind. After you've done it once, it's a breeze. The whole procedure can be done in 5 minutes.
Received 3,858 Likes
I actually just did mine this morning in my dorm parking lot for the first time and it took me a total of like 20min.
Originally Posted by Sun Diego CL-S
it sounds like you went underneath the car throught the splashguard to do this. it's faster just taking out the single screw next to the foglight in the lower grille.
3 the Hard Way
I want to put the white PIAA's in, but I don't like how during the day they stick out like blue nipples. Is there some kinda paint to make them clear, or maybe a clear bulb with similar output?
blue nips
testicles (because one exhaust hangs slightly lower than the other one)
Anyway, I do have to say that the PA19224 looks so much better than the stocks... I don't think it will burn the housing either because I felt the housing after hours of driving with lights on, it was just warm. So PA19224 has my
3 the Hard Way
Where do I get that paint that people use on bulbs to make them barely noticeable behind clear glass? I KNOW it exists, because I've read about it somewhere before, I just don't remember what it's called. As much as I love nipples, I don't want nipples in my roadlamps.
3 the Hard Way
Originally Posted by Baylove
get some polarg m6's, they look the best
Again, not trying to be rude, but it irks me when someone asks a real specific question and you hear "screw this, get that" or something to that effect. All it does is make the thread unneccessarily longer.
With that being said, back to my original inquiry:
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
