Phees LED Guage DIY for Acurazine
9932 contacted me about doing his guages in LED fashion and i decided to make this a diy. now i understand that many of you guys will not be willing to tackle this on your own but i will provide pics for those of you who just need visuals.
Materials needed:
scissors
3m double sided molding tape (its thicker than office tape)
LED bulbs
1/4 watt resistors (same amount as bulbs)
soldering iron thats under 30 watts but over 20 watts
small glasses sized philips head screw driver
flat head screw driver
18 guage wire
thin cardboard or another thin insulator (non conductive material)
ill post this to build an audience. stay tuned.
it happens tonight
Materials needed:
scissors
LED bulbs
18 guage wire
it happens tonight
B A N N E D
Materials needed:
scissors
LED bulbs
18 guage wire
it happens tonight
Materials needed:
scissors
LED bulbs
18 guage wire
it happens tonight
waiting :twittle thumbs:
Whats up with RDX owners?
waiting impatiently!!
Materials needed:
scissors
LED bulbs
18 guage wire
hot glue gun
blade
acetone
cotton swabs
alrights guys
im not going to explain how to get the guages out of the car because its easy to figure out and if someone wants to post this instructions go for it!
once you have the guages out you must take them apart.
the guage cluster consists of 4 plastic parts
the clear
the rear white backing
the black face bezel
and the actual guage holder/pcb mount
all of these are removed by pushing the clips out of their resting points with a flathead screw driver.
NOte: be careful with the clear part because it will crack if u dont push out every clip before attempting to remove it.
once all the parts have been seperated you will be presented with the bare guages.
remove the needles by using two spoons on either end of the needle base and wedging them under and pushing up.
should look like this \-/ the dash is the needle base and the slashes are the spoons.
BE SURE NOT TO BEND THE NEEDLE OR ITS METAL STICK THAT GOES INTO THE MOTOR
once all the needles are removed you can remove the guage faces by peeling them off gently (there is double sided tape that u must reuse under them.)
take the faces off and scrape the blue filter off of the back of them. some people use nail polish remover and say it works wonder. its up to you.
just make sure to remove the blue filter because it will mess ur light output up.
now onto the actual process
1st: solder resistors onto the postitive side of every LED that you have. (the positive side is the one with the longer end)
2nd: use the double sided molding tape to create a laying mat for the LED's around the center part of the guage motor the tape will allow u to move the LED's later without too much trouble.
once everything is in place you can use your hot glue gun to keep the bulbs in place. be sure not to get glue on the rounded end of the LED because it will mess up your light pattern.
3rd. wiring. i decided to wire the LED's in parallel instead of series. this way, if one bulb goes out. all the other ones continue working and u can fix that one bulb without having to rewire the entire cluster.
the way i did this is pictures below where the outer "ring" of wire is the positive or "hot lead. and the inner wire is the ground wire or negative wire. i placed a shaped piece of gloss cardboard between the neg and pos terminals of the bulbs to prevent shorts.
4th. Test your leads.
Grab a 9 volt battery and attach the positive end of it to the positive cable and the negative end to the negative cable. This will light up your LED’s and if one is bad/wired wrong. It wont light up.
Test both the speedo and the tach.
5thonce you’ve tested. You can connect the positive cable of the tach to the positive cable of the speedo and do the same for the negatives of the tack and speedo.
6th then wire the other ends out of the guage cluster through the bulb hole for wiring later. Test again and make sure everything lights up together.
7th. Gas and temp.
4 LED’s in an X configuration. All positive ends soldered to one hot wire and all negative ends soldered to a ground.
8th. Connect the temp and gas to the speedo and tach wires and test
9th. Now for the info display
Fab a mount just like the one pictured below with the cardboard.
10th pic below is of the 6 wires hooked up and consolidated into 2 wires.
Also a pic of the cardboard barrier that u must create for the info display in order to prevent the bulbs from shorting out on the speedo circuit board.
Remove all the OEM speedo, tach and temp/gas bulbs. All the other ones stay.
Materials needed:
scissors
LED bulbs
18 guage wire
hot glue gun
blade
acetone
cotton swabs
alrights guys
the clear
7th. Gas and temp.
Any pics of it lit up with the faces on?
I like the fuel and temp gauges, the way they fade to red. Looks nice.
Is there a film on the odometer as well? I hate the blue that the white lights give off. Luckily when I did red the red overpowered the blue.
The blue doesnt go IMO.
I wouldve gone with red, at least thats on the gauges.
for those who would rather not remove you needles here is how to remove the guages from behind.
If you look on the back of the cluster you will see where the gauges are connected. The two metal clips that are bent inward onto the circuit board must be bent upward, then take a small screwdriver to push the middle part, in which the gauge will then pop out.
courtesy of OntarioTL
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Very nice diy, glad all I had to do was swap in some LED wide angle LED bulbs for my gauages, but I did have to do something similar for my climate control. Nice work
To many cars in my garage
This is how I did mine but now im having this issue with my gas gauge it is full but wont go past half is that because I dint pust them down hard enough when I put them together should I just soder it down ??
