Passenger jack point "imploded"! Ever happen to anyone before?
Liquid Ice
Had my car on a hydraulic jack this weekend and luckily a jack stand underneath the car when all of a sudden BOOM ... the front passenger side jack point for my car bent forward towards the passenger side of the car ...
It didn't fall off, instead of facing downwards, it now faces outwards!?! I have my car scheduled for a Thursday appt. anyways for the Timing belt tensioner recall... but I was wondering if this has ever happened to anyone? I'm lucky I used a jack stand, or else the car would've probably landed on the wheel assembly since I had the tire off..
Let this be a lesson to everyone who doesn't use a jack stand ... They're very important!
BTW- Do you think this will be covered under warranty? I was the one who put the car on the jack, but I don't think the jack point should have broken like that...
Daily Driver
If I understand this right, you had the hydraulic jack at the jack point and the jack stand somewhere else under the car.
If your hydraulic jack is like mine, it doesn't have a groove for the jack point metal piece, so that piece would have just been sitting on the hydraulic jack in that dish-shaped metal piece. I can imagine it bending I guess, though it's never happened to me. The jack point there seems like it's designed for a jack stand or the scissors jack in the trunk.
For other ideas on where to jack it from, check out:
http://www.acura-cl.com/forums/showt...ght=jack+point
Yes absolutely it has happened to someone on here before. And you've seen him holding a big big rifle....
I would never ever get under a car, hydraulic jack, jack stands, even if you drove the wheels up on a curb. Never get up underneath a car even with four wheels on the ground.
What's the definition of a "freak accident?"
A relative of mine died because his car fell on him. He had done it a hundred times before, but just like ken's saying "freak accident". be careful when working on your car.
Liquid Ice
It could be the car was lifted incorrectly before at that point and your lifting was what it took to bend the metal .You might have scraped that part of the car over something bent it and not realized it and the jack finished the job? Just guessing here .I see them bent over every once in a while .Mostly if the person lifting fails to get the jack or the lift set up correctly it can cause this problem especially if it is done several times .
Jens
Jens
rockyboy
08-04-2024 10:35 AM
justin7779
12-25-2015 10:33 PM
