P2R plenum and 4inch intake by powerrevracing.com. ANY GOOD GAINS????
Old 01-30-2010, 11:59 AM
  #41
lowrd on tein CS biatch
CL-S progression 01's Avatar
how large is our OEM typeS throttle body?
and how do I go about getting a bigger one and what size should I go?
Old 01-30-2010, 12:43 PM
  #42
3.7L Nitrous Breathing CL
richardparker's Avatar
OEM I think is around 68-70mm.
You would'nt need no more than 76mm unless you had a huge intake (High volume)and high lift cams and alot of fuel.
Old 01-30-2010, 02:36 PM
  #43
OK and how do I go about getting a 76mm tb??? who makes them for our cars?
Old 01-30-2010, 03:12 PM
  #44
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,457 Likes on 4,978 Posts
Right about size. Wrong about what this engine needs. These motors love to breathe. When you open up the intake and exhaust they'll keep making power. My old motor wouldnt make power past 6k rpm. Now it stops making power even lower.
Old 01-30-2010, 03:34 PM
  #45
^^ you lost me there civicdrivr
did you mean "now it stops making power even higher" ?
because you said "now it stops making power even lower"
which doesn't really correlate to your theory of how these motors love to breath. So i assume you meant it makes power even higher, now that u got the exhaust and the intake modded.
So my question is.
What size throttle body should I get? and who makes them
Old 01-30-2010, 03:47 PM
  #46
civicdrivr's Avatar
My motor wont make power above 5k rpms now. I opened everything up but the exhaust and throttle body so far.
My throttle body is small. Its 71mm in and 70mm out. Its not supplying nearly enough air.
So my question is.
No one makes them. Anything larger then a stock ported throttle body is a custom application.
Old 01-30-2010, 04:23 PM
  #47
I thought P2R does custom throttle bodies? or do they not do that anymore
Old 01-30-2010, 04:29 PM
  #48
civicdrivr's Avatar
He ports the stock throttle body.
Old 01-30-2010, 04:47 PM
  #49
Lone Wolf
brian6speed's Avatar
p2r can bore out a stock tb from 70mm to 71mm i believe. For you cl-progression i would avoid the custom one. It requires more work than just swapping a larger tb in. A larger tb alone wont really help since its restricted airflow in other places. If any of my info is wrong pls correct me.
Old 01-30-2010, 05:50 PM
  #50
civicdrivr's Avatar
For his motor you are correct. Hes got stock heads and a stock manifold (by that I mean its not ported).
If using the 3.7 intake then there is a benefit to running a larger throttle body. Or if you port the entire system (such as my motor) then the stock or ported tb isnt providing enough air.
Old 01-30-2010, 07:15 PM
  #51
tru I guess I should just leave it alone then.
finish the exhaust
Old 01-31-2010, 04:01 PM
  #52
I Drive Like A Dick 8≈
Nersh7's Avatar
nothing is ever finished
either you will want a different sound or are bored
or
do a real dual exhaust
Old 01-31-2010, 05:40 PM
  #53
lol I am just gonna do the XLR8 cat and call it a day for now
Old 01-31-2010, 08:14 PM
  #54
3.5 psi
gnuts's Avatar
You cant weld magnesium
Wouldn't it be easier for you to keep the TL manifold, make a custom adapter to replace the P2R one, and weld on a bigger throttle body to that?
james357
02-13-2016 02:37 PM
drone619
01-26-2016 07:09 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
obert
09-03-2015 08:40 PM
NSolace
09-03-2015 08:02 PM
Quick Reply: P2R plenum and 4inch intake by powerrevracing.com. ANY GOOD GAINS????
