Option pulley question
Old 05-09-2009, 01:47 PM
  #41
2Fast4you's Avatar
x2.
Was your breaker bar secured properly against the ground?
yes it was
Old 05-11-2009, 10:35 AM
  #42
2Fast4you's Avatar
so I called around and the most cheapest price I found was 120 dollars to install the pulley and the belt he said it would take about 1.5 hours is this a good price it seems alot for a simple job like this
Old 05-11-2009, 01:15 PM
  #43
B A N N E D
StonedCL's Avatar
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
My shop charges patrons $95 / hour.. Its a Saturn dlr..
They charge us workes $35 / hour.. They charged me a hour labor..
I would think u can get it done for under $100...
Old 05-11-2009, 04:13 PM
  #44
2Fast4you's Avatar
well got it installed today for 85 dollars at my mechanic and guess what else he found..... busted motor mounts and he said it would be 475 dollars to do the side and front I told him I can do the side one myself. It would cost around 300 dollars for parts and labor for a front motor mount is there a cheap motor mount that I can get that is less than 130 dollars which is what he charged me?
Old 05-11-2009, 06:15 PM
  #45
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,458 Likes on 4,979 Posts
The front motor mount :
50800-S0K-A82
$104
The rear motor mount :
50820-S3M-A81
$58
Prices are from magauto.com. They are local to me and theyre good people. If you call them ask for Chris or Rob.
Old 05-11-2009, 06:46 PM
  #46
2Fast4you's Avatar
50800-S0K-A82
$104
50820-S3M-A81
$58
thanks man do you think if front and right motor mount need replacing that my left motor mount would need to be replaced? Also are these the best prices that you could fine?
Old 05-11-2009, 06:54 PM
  #47
civicdrivr's Avatar
Those are the prices from the Honda dealer I get all my parts from. Just do a google search for the part numbers, you may be able to find them cheaper.
I doubt the two tranny mounts would be toast, I dont think that are filled with any liquid, but those are cheap if they do need replacing.
Old 05-11-2009, 08:50 PM
  #48
Likes it dirty
Ricepuddin's Avatar
Got mine in today! Going to take it to the hobby shop ( rentable garage space for the military) and try installing it myself, if i can't break the nut my mechanic is going to be receiving more of my money.
Old 05-11-2009, 08:56 PM
  #49
B A N N E D
StonedCL's Avatar
I think someone make a poly mount for our engin if im not mistaken.
The engine and tranny mounts are know to go in our cars. My engine mont went at 100k and tranny mount broke 3 times all-ready, and you really cant notice the tranny mount being broken unless u put it on a lift.
I dont know about the 6 speeds but auto tranny mounts are week also.
I would check on polyurethane engin mounts and put those on and NEVER have to worry about it again!
Old 05-11-2009, 09:19 PM
  #50
civicdrivr's Avatar
Stoned:
You talking about the DIY poly mounts or the Innovative mounts?
I recommend doing the DIY poly mounts. The Innovative mounts have plenty of problems, more then the OEM mounts.
The tranny mounts are located on the subframe right below the tranny. You need to look at them from underneath the car. Easy to spot.
Old 05-11-2009, 09:22 PM
  #51
2Fast4you's Avatar
just be carefull man I got carried away with mine but if it doesnt come off easy just let a pro do it
I heard the poly mounts are not very good im probably just gona get the oem ones
Old 05-12-2009, 09:55 AM
  #52
2Fast4you's Avatar
since my motor mounts are busted right now should I take any precautions to limit any damage I might cause
Old 05-12-2009, 10:23 AM
  #53
B A N N E D
StonedCL's Avatar
OK i though i reat that the inovative mounts where great but i can be wrong. (I ussally am) I dont know if u have to be coutiuos it prob has been broke for some time now and u have not noticed it. I would stay away from doing sudden manuvers like quick stops ar WOT till it gets fixed!
Old 05-12-2009, 03:22 PM
  #54
01RedCLS's Avatar
So those that have the Option Pulley installed - what are your initial impressions??
Old 05-12-2009, 08:55 PM
  #55
B A N N E D
StonedCL's Avatar
Normal driving NUTTIN different WOT (wide open throttle) you do feel the RPM's clime quicker. 7-10 HP is not much of a difference. I think I am doing a little better on gas milage.. It could be my imagination!
Old 05-13-2009, 06:55 AM
  #56
lowrd on tein CS biatch
CL-S progression 01's Avatar
k so I'm just gonna buy the biggest baddest impact Gun I can get my hands on so I never have to have this stupid tq issue again. Question for you guys... think this MAC will work? I tried a gun with around 500ft/lbs and did JACK shyt.
http://toronto.kijiji.ca/c-buy-and-s...AdIdZ120387983
it's got 1000ft/lbs of tq
If so i'm buying it tonight, or tomorrow when buddy responds.
Thanks!
Old 05-13-2009, 11:06 AM
  #57
2Fast4you's Avatar
im thinking about doing the DIY where you fill the motor mounts with poly it will save me alot of money. Do you think this is a good idea?
Old 05-13-2009, 11:40 AM
  #58
civicdrivr's Avatar
Yes! I absolutely love my car now. Im running 80A, which is noticable firmer. If you want comfort Id suggest going with 60A.
CL-S
I'd go with a 3/4" impact gun, not a 1/2". Also, the size of your air hose has an effect on the air pressure at the gun. I like MAC tools, but I find them to be a bit overpriced.
Old 05-13-2009, 04:25 PM
  #59
2Fast4you's Avatar
So you have done this mod? Since my mounts are bad do you have to like cut of the old rubber for the side one and for the front Im not exactly sure how to do that one. I found the DIY for this but it wasnt very descriptive
Old 05-13-2009, 05:09 PM
  #60
k well i'm buying it regardless, cause it's the only thing with 1000 tq for the price and this thing is barely used... I got an industrial air compressor at a family shop of mine as well, and it's got a 1/2 inch hose.
Why go 3/4" drive??? what's the difference? Less likelyhood of snapping a socket?
This will SLAP off that crank pully bolt for sure though right?
Old 05-13-2009, 05:21 PM
  #61
2Fast4you's Avatar
more torque heavier duty I had a 1/2" impact wrench at 700 torque and it didn't get it off
Old 05-13-2009, 05:27 PM
  #62
so what are you saying 1000ft/lbs of tq on a 1/2" isn't gonna cut the cheese?
did you have an industrial compressor and a 1/2 inch hose?
Or should I really be going for something more like this one on ebay?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=120417944020
Old 05-13-2009, 05:40 PM
  #63
2Fast4you's Avatar
A industrail compressor really wont make a difference as long as it puts out 90psi which most do then your good the hose will help but idk when I put my impact wrench on the bolt it didnt even have enough torque to turn the pulley with no one holding it and that was 700
Old 05-13-2009, 06:39 PM
  #64
mine does 150psi all the time man. and that gun is sold so i'm fakeddd..
I i think i'm just gonna have to let someone else geter done.
Old 05-13-2009, 07:16 PM
  #65
2Fast4you's Avatar
most impact wrenches only take up to 90psi
Old 05-13-2009, 09:54 PM
  #66
civicdrivr's Avatar
I sent you a PM.
My 1/2" drive Craftsmen couldnt break the bolt lose. I forget what model but IIRC it puts out 6-700tq. The starter puts out more TQ though
Old 12-20-2010, 03:13 AM
  #67
6spd
Jaeson's Avatar
Originally Posted by JayT
GATES K060441
GATES K040425
I ordered mine from www.rockauto.com
Both Rockauto and Amazon say that those are not the correct part numbers.
GATES Part # K040438 K04 9/16" x 44 3/8" Micro-V AT Premium OE V-Ribbed Belt
Power Steering
GATES Part # K060461 K06 13/16" x 46 5/8" Micro-V AT Premium OE V-Ribbed Belt
Alternator and Air Conditioning
The lengths seem to be different....Anyone know which ones are correct?
Old 12-20-2010, 09:19 PM
  #68
civicdrivr's Avatar
The lengths are different because the underdrive pulley requires a shorter belt. If you put in the car info, its going to tell you the correct belts are incorrect.
Old 12-21-2010, 03:53 AM
  #69
Rapture's Avatar
lol yeah I guess Amazon.com knows more about this than the people who are currently using the pulley.
Old 12-21-2010, 07:02 AM
  #70
fuzzy02CLS's Avatar
GATES K060441
GATES K040425
These are 100% correct for the pulley. I just bought them for my upcoming 105K mile service.
Old 12-22-2010, 07:24 PM
  #71
6spd
Jaeson's Avatar
Oops my bad. I was just using search and didnt even notice the thread title
BoricuaTL
04-08-2016 01:08 PM
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
12-22-2015 12:46 PM
navtool.com
ZDX
10-31-2015 08:26 PM
datadr
09-12-2015 09:12 PM
datadr
09-02-2015 06:46 PM
Quick Reply: Option pulley question
