OMG HELP my stupidness used a brillo pad =(
used blowdryer for less then a minute on my 3.2 CL TYPE-S emblem, used dental floss to peel it off, still had sticky stuff left on , dont kno why but got a brillo pad/green scratch thing for dishes, and tried to get the sticky stuff off. now have an area the size of a hand full of scratches.. PLEASE HELP!!! wut should i do. =((
it probably needs to be lightly sanded w/ 1500 grit sand paper and buffed out.
something witty
OMG that fucking sucks.
I feel your pain cause when I was 16 I did it myself. ONe of those things that you wish somebody would have told you. Coarse materials are BAD for your car.
6G TLX-S
Wax that area with some car wax. It will remove light scratches.
Old&CnL
Polishing Compound should work!!
will probably remove it; then use Scratch X from Meguairs (SP), then a good wax. You will never know it was scratched. Next time use alcohol or an "Oops"type cleaner used lightly with a paper towel or q-tip.
Originally Posted by joseph_99tl
it will reappear.
the buffing and waxing are temporary cover ups.
they have colored waxes that might help.
if done correctly it will never come back.
just waxing it wouldn't work very well at all. the scratches from a green brillo pad are at least 400 grit
Regions Leader
Regions Leader
Originally Posted by dfv3.2CL-S
Brillo pads is a no no for a car finish. Try to use light cut rubbing compound and see if it will take the scratches out. Next time go to Auto Zone and buy sticker remover solution.
Agreed........they have solvents out there that take glue off pretty easy.
ok im a big newb at this stuff... wut will lightly sanded wit sand paper do? wont it create a deeper scratches?? and lets say i do that where and how would i go about gettin that stuff ??
if i go that route could that work too? im on a budget right now so im tryin to go the econimacal way but i still wanna get those scratches out. thanks for all the posts didnt expect so many replies back.. anyother suggestions are always welcome thanks fellas.
Flap.
you were recommended very high grit sandpaper... it will evn out the surface and then need to be buffed to restore the shine...
sandpaper can be purchased at any home improvement store....
Old&CnL
Find a local Auto paint shop- they carry #2000 grit wet sand paper. Hint: Cut a small strip off and soak it in water overnite- this really helps keep down the roughness even further. Use prenty of water when sanding and use a really lite touch!!
Learn to swim
Originally Posted by Bluto
Sounds like you have never wet sanded anything. I would see a pro detailer or paint shop.
Werd.......
If you cut through the clear coat, you are screwed
GEEZER
Damn!! I did not expect anyone to take me serious...:gheylaugh:
https://acurazine.com/forums/showpos...0&postcount=11
Although it's too late now, you should have used a dab of Goo Gone. (That's what I did when I removed the badges on my Accord.)
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
