Oil change for 01 CL-S
4th Gear
My brother has a 01 CL Type S and we need to know how much oil it takes? When he bought the car it didn't come with a drivers manual and we called an Acura dealership and spoke to people from the service center and they also did not know. Weird Thanks
It's Always Shabbat
I'm an idiot.. I just bought a gallon of Mobil-1 Syn 5W-30 at KMart but only then realized that it takes almost five quarts.. Guess I need the big one-gallon jug and a single quart..
Originally Posted by Brady6226
.25 quarts over= ok
1 quart over= bad very bad
it is worse on your motor to have too much oil than not having enough.
but 0.4qt over 4.6qt is also OK, I can assure you. Engines desiged to operate with more oil that manual says. they provide a safety net of +/- 0.5qt.
Engineers design engines to be tolerant to a slight variations in the oil level.
Thats why an oil stick has min/max marks... and even max is not a true max.
Look I'm really not trying to be mean although this may come off as just that but if you cant find the oil drain plug you should consider having someone else change your oil
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
