NOS & CL-S -- NSX System
Ok I talked to NOS Systems and they told me to use the NOS Kit for an NSX. Anyone that can confirm that? Someone help me out, don't want to waste money!
Also a quick note - they told me to find out if we have a "vacuum sensitive fuel pressure regulator", so I called my local dealer - Wier Canyon Acura, after talking to a tech they said we don't have one of those. Everything is done electronically. Not trusting them I called up Park Avenue Acura, and got the correct answer. We do have one! - I wish I was on the east coast!!!
01 CL-S Navi - Black/Ebony
Xephyr CAI with I get my Car back
Alpine MRV-1507 V12 Amp - Tested @ 1,237 Watts RMS - 2,078 Watts Max
2x Alpine 12" Type R - Custom Enclosure
Escort Passport 8500
Yea, the NSX one would be fine. It is primariy based on the engine displacement. We we both have 3.2L (196 ci for us non-metric compliant people), it would work ouf fine.
They really just supply a generic EFI kit with jets more closely sized to our engine.
As for the statement about a non-vacuum controlled regulator. I certainly would not use that dealer. The idea of using a vacuum controled FPR is to maintain a constant pressure ratio across the inject tip. Without it the fuel mapping would be signifiantly more in depth.
Did those guys ever open the hood or the shop manual and look at the fueling system??
Would you guys recommend Nitrous Expres or NOS Systems? The Nitrous Express system is cheaper by about $75
NOS's EFI kit is a dry system.
Nitrous Express is a single nozzle wet system.
Two different types.
I have no idea how long the intake runners on the CLS are. It's not a good idea to run NX/wet system through long intake runners. Intake runners are made to flow air and not fuel.
NX/wet system works great on 4 cylinders Honda/Acura because they have a very short intake runners. It does very poorly on LT1..etc.
NOS's solenoids are more reliable. NX's accessories are more advance.
1999 Nissan Maxima
[This message has been edited by 1max2nv (edited 05-03-2001).]
<font face="Verdana, Arial" size="2">Originally posted by Aysle:
</font>
</font>
1999 Nissan Maxima
Wet means it mixes with the fuel first, dry means it sprays it directly into the intake valve or something? ![](http://www.acura-cl.com/ubb/confused.gif)
Btw, has anyone tried NOS on the higher compression CL-S before? I'm worried.![](http://www.acura-cl.com/ubb/frown.gif)
-J
2001 CL-S Aegean Blue/black interior spoiler, wheel locks, no-navi
Stock for now.
-J
Stock for now.
Wet system means the nozzle sprays fuel and nitrous at the same time. Dry system nozzle only sprays nitrous. There are few different types of wet system. Single nozzle, direct port or plate system. The placement of these nozzle/nozzles is what's different between these wet systems.
Nozzle placement for NOS dry kit and Nitrous Express single nozzle wet kit is the same. You want to put it between the MAF and the throttle body.
1999 Nissan Maxima
<font face="Verdana, Arial" size="2">Originally posted by JRock:
Wet means it mixes with the fuel first, dry means it sprays it directly into the intake valve or something?![](http://www.acura-cl.com/ubb/confused.gif)
-J
</font>
-J
</font>
1999 Nissan Maxima
No MAF here, The CL uses speed density. Secondly, is a single nozzle wet system were used, problems could certainly come up.
You could get puddling in the plenum end tanks. If you went multiple nozzles wet system. You could plumb into the center plenum chamber and tap directly into the down runners. This would be very effective (might disturb the IMRC flow a bit, not sure though) system by being right above the ports. But complicated to install.
A dry system would be much easier to implement in this case. A single nozzle just after the TB right at the plenum split. I had forgot that NX used a wet system in their basic EFI kits.
NOS then..
NOS then..
RWD convert
I saw a stock CL-S running a 100 shot NOS at Moroso race track. That was his only mod. He ran a 13.6
Y2K Satin Silver/Ebony 3.2TL
AEM Short Ram intake | Magnaflow quad exhaust | Ground Control coilovers | BOSCH platinum+4 plugs | Blitz coolant pressure riser | Factory underbody kit and Wing | Mesh grill | Body color door handles | Lighting:Polarg M12 sidemarkers/Opti-Blue Xenon HighBeams/Eurolite 168 Xenonbulbs/Hiper Strobes | 20%/35% Llumar Platinum tint | Räzo Shifter and Alloy pedals | 2 Rockford 10" XLC subs pushed by Boss Audio CLR60 amp | Escort Passport 7500
I would still put the dry nozzle right before the throttle body and not after like you said. What if the soleniod get stuck open? If it's before the throttle body, the throttle plate will limit most of the nitrous from flowing into the engine all at once. The nitrous would just all run out towards the airbox/fiter.
1999 Nissan Maxima
<font face="Verdana, Arial" size="2">Originally posted by scalbert:
NOS then..</font>
NOS then..</font>
1999 Nissan Maxima
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
make sure to put the nozzle at least 6" in front of the TB in the intake
my mom and bestfriend have told me to tell you guys to stop telling me to spend my money; they are tired of my automobiles getting pampered and them getting whats left over which usually consists of change I find in my car by doing things you guys encourage
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I would NOT do anything to my baby that would VOID the warrenty.. And I really think NOS would VOID warrenty.
<font face="Verdana, Arial" size="2">Originally posted by StonedCL:
I would NOT do anything to my baby that would VOID the warrenty.. And I really think NOS would VOID warrenty.</font>
CLPower:
Im sure you already know this... but for everyone else's benefit....- Automobile grade NOS is mixed not pure N2O .. With a sulfur % to discourage "misuse" from pharmaceutical grade N2O...... The reason NOS gives the yellow/brown smoke...... if you blow your tranny or worse a competent mechanic will see the tell-tale signs in the form of anything from scorched/fouled heads, pistons, valves, cats, tips ..-etc...- be wary ..... or very sneaky. lol
Chris
2001 Nighthawk Black CLS Type S - Xephyr Performance CAI, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, 1/4 Mile in 14.424@97.23 MPH Atco Raceway Best GTECH Sprint 5.55with Poobah watching
Xephyr Performance Intakes
Chris
White Lightning
Can anyone just tell me which one to get? I want NOS to go faster. I'm sick of getting low 15s....help me guys. Appreciate it.
Let me know if i need to upgrade my engine before getting the NOS.
NightHawk Black CL-S
Black Interior
Clear Headlights
Nokyo Halogen Bulb Artic White
AEM Cold Air Induction
Now Working to Get Springs
Black Interior
Clear Headlights
<font face="Verdana, Arial" size="2">Originally posted by Xephyr2K:
CLPower:
Chris
</font>
CLPower:
Chris
</font>
2001 acura cl type-s
comming soon
2000 accord v6 sedan
1997 4runner
1992 camaro
1993 volvo 850
"THE GREATEST TRICK THE DEVIL EVER PULLED, WAS CONVINCING THE WORLD HE DIDN'T EXIST"
<font face="Verdana, Arial" size="2">Originally posted by X3.2CLSX:
</font>
</font>
CLPower - Did you put the attach it to your CAI?? Do you have a pic?
<font face="Verdana, Arial" size="2">Originally posted by 1max2nv:
</font>
</font>
But I guess it could be placed prior to the VSA throttle. But that is just rubber hose...
White Lightning
I talked to NOS Systems and they think our car should be fine with a 50 or 75 shot. Im getting it for $499 and having a friend help with the install.
</font>
</font>
CLpower, maybe you can take a picture of your engine so we have an idea of what our engine should look like.
Black Interior
Clear Headlights
Also, can a professional install the the NOS?
</font>
</font>
White Lightning
Im getting the system around Tuesday and I will take pictures of the install. The instructions are REALLY simple, only like 3 pages with BIG type. You can have it professionally installed. I got quotes of around $900 for system and install.
</font>
</font>
Black Interior
Clear Headlights
I guess that NOS is the make that everyone is looking at??? What about Zex? Do they make quality stuff???? I was about to buy a zex system, but since I see you guys talking so much about NOS...I may just change my mind.
Black Cl-S, Navi,
Chrome Avez 18"s
AEM CAI is on its way...
2 12" Flat Piston PPI Subs, MPS-2500 Pheonix Gold Amp, Clarion Cross-over, Spoiler, Mud gaurds
Black Cl-S, Navi,
Chrome Avez 18"s
<font face="Verdana, Arial" size="2">Originally posted by Vector02:
</font>
</font>
The other main reason with going with NOS is because the are BIG and have a huge market share - they must be doing something right. Also I got to go down to their West Coast office and check their stuff out. Was alot of fun.
Other than that though NOS, ZEX or Nitrous Express I don't think it matters to much (except that Nitrous Express is a WET system which sucks). Its not like spray N2O into the intake is that complicated.
Also if you want to see what the install actually involves, I scaned a few pages of the instructions.
http://albums.photopoint.com/j/Album...a=12817123&f=0
[This message has been edited by Aysle (edited 05-04-2001).]
RSpyder
09-30-2015 12:46 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
