NGK or DENSO plugs?
NGK or DENSO plugs?
going to get some plugs for her,
i've heard the hotter ik 20 or comparable ngk are preferred.
wondering if anyone thinks the denso is worth the extra 20. can get them on ebay for like 40 ngk/60 denso shipped.
thanks
Joe
thanks
Joe
thats what I was referring to, sorry should have specified. i'd like to go iridium, not sure if the denso are worth the 20$ more than the ngk.
thanks
Joe
thanks
Joe
Just FYI, the '03 came with NGK Iridium plugs, IZFR6K. I replaced them with the Denso IK20's after a misfire problem. Am now running the IK22's with the blower.
go like hell
1 Post
Re: NGK or DENSO plugs?
thanks
Joe
thanks
Joe
EVERY MOTOR i have has NGK plugs in it. Why do i swear by NGK. well I used to be a Champion(which is basically Bosch(it's like a GMC pickup it's basically Champion). anyhow I used a Champions in my sister's car(now the plugs were "rated for 90,000) after about 55,000-60,000 miles of use the plugs were TRASH. they were black and crappy looking.
Now I put in NGKs in ran the same car (which are rated for 90,000 miles) checked them after same amount of miles they look pretty good. there's some wear you can tell( but you can still get about a year or 2 off of those plugs).
by the way roo97ss: if your buying a C/T S/C make sure to change the plugs before you bolt on the S/C because you can't access the plugs with the S/C on. I know you can take it off. but it will save you 1.5 or 2 hours of work
Re: Re: NGK or DENSO plugs?
VOTE OUT THE BUSH REGIME
SC kit comes with denso IK 22
I heard bosch platinum4+ isn't good to run in our engines?![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
NGK is cheaper but IMHO you will not notice any difference in spark unless you are heavily modified
Sweet as Gold
aight...the manufacture recommendation is 100K or 90K...but they also say change ur oil filter every other oil change...do u trust that. I don't and I hope no one else does either. This is the same thing. I pulled my plugs out at 45k to see how they were doing and they seemed fine but I think I'm gonna change them at around 60K. I just don't trust 90-100K of my driving style on plugs...I don't care what the recommendation is
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
