New mod idea - anyone seen or done this?
I'm here in spirit...
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
I was thinking about doing this little mod that I’ve seen in newer high-end cars and I am wondering if anyone has tried it.
In the TSX loaner I had there was a tiny blue light up by the sunglass holder. (like an led or something). At night it lit the front area of the interior around the center console just slightly enough to see. It is a very soft light, not ricy at all. My mom’s old 530i had one too but her’s was red. Anyway, it is kind of a trick little feature that I was thinking of trying in my car. Has anyone done this and if so, what kind of light did you use? I wonder if it would be hard to wire up. Anyone have any ideas??
Thanks in advance!
Thanks in advance!
I need a Hybrid CL-S
If you did something like that and for it to look good, i would think it would need to match the color of the interior lighting in the vehicle. It looks good on the tl because the dash and radio and all that lighting is blue. I think one blue light in a cl would look silly, unless you changed all your interior bulbs. just my opinion.
I was actually thinking red. The one in my mom's bimmer was red. She had tan interior. As for the dash lights, I tink they were that orange/red color. Who knows, maybe you're right. Still kinda like to try it though.
Originally Posted by mrsteve
Just a basic LED. Not all that complicated. Drill a hole, mount the LED, wire it into the power for the auto-dim rear view mirror. Done.
Flap.
Originally Posted by gary_william
yeah, it's a little more complicated than that. LEDS require certain voltages and amperages, so just throwing 12 volts across is will make it real bright, for about 20 seconds, then it wil fry. Go to www.ledsupply.com for information about "drivers" which are basically variable resistors, or better said is that they are mini power regulators. Look for the "buck puck" model for 12V in. You will need to use more than 1 LED, though.
obviously you need a resistor... ooh and i think you should point out that you might have to solder....
no, no "resistors" required if you use the "buck puck", as it IS the "resistor" so to speak. The buck puck regulates the voltage output and provides a constant current, so think of it as a dynamic resistor. Soldering will be required, though, you are right.
Obviously there is more to power supply that just splicing two wires... I didn't feel the need in stating the obvious. Although I don't see any need for more than 1 LED. If you know how to solder it shouldn't be that complicated to hook up.
Originally Posted by quicksilver10101
go to superbrightleds.com
What about this. Go to this link http://www.superbrightleds.com/mini_tubes.htm# and there is a "LED Wire" at the bottom of the page. You guys think this would work?
DerrickW
11-15-2015 05:52 PM
lanechanger
10-13-2015 10:56 AM
