New Member with Questions
3rd Gear
I came across this site while reasearching a new car purchase. It seems that the CL has a huge following, which is great.
In the end, I decided on a standard '03 CL, but have a few questions.
I want to modify the car, but not sure where to start. This will be the first car that I make any changes to. So far, I have only driven and owned stock-version cars.
What should be done first?
- Intake
- Unichip
- CAI
- Pulleys
- Other ideas?
Anyway, I am sure this question gets asked a lot, but I figured I would throw it out there and see what you all think.
Thanks,
Aaron
- Intake
- Unichip
- CAI
- Pulleys
- Other ideas?
Thanks,
Aaron
Yeehaw
Like fuzzy said, depends on what you are going for...handling, speed, looks etc...and how much $$ you want to spend.
Personally, I would do the comptech drop first, then intake and headers.
I've said it before, and I'll tell you too .... if I could do it again I'd improve the handling first after getting the intake (the sound is so intoxicating ). The car is pretty quick stock.. but the handling is a little floaty... especially on the CL-P.
The order I'd go is:
* Intake - the sound is sweet.. and the 5-7hp isn't bad either
* Springs - get rid of the float
* Rims/Tires - or just tires... either way, get rid of the stock rubber
* Sways - now that your lower and have better rubber.. get rid of * lean for good
* Headers - on the CL-P you'll only gain about 15-18 hp.. but still not bad
* Exhaust - nice looks and sounds... 1-3hp max
Get the handling to where you like it then go for the performance increases. What good is speed if you can't grab a turn?
3rd Gear
Thanks for the replys. There is jus a lot to consider. But, I think I will start with handling first then go for speed.
So, I think I will take Fuzzy's advice and start with the intake.
Again, thanks for all the suggestions.
Got a Job!
hey, just to further investigate the suspension thing...
Which would be better for ride comfort (I drive every-day, and commute to school an hour away, so i want a NICE comfortable ride, just like stock, and NOT bouncy)...
Tein SS coilovers
or
Comptech / H&R Sport Springs
Koni Yellows
(or whatever other combo would best suit my situation)???
Tein SS coilovers
or
Koni Yellows
3rd Gear
thanks to everyone that replied to my message. i did not expect to many reponses. you all rock!
anyway, it seems that i first need to start with the intake and then build from there. i am looking for both speed and handeling. so, it will be a little bit at a time
oh, my car is is silver Metallic w/ bony int.
again thanks,
aaron
again thanks,
aaron
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
12-22-2015 12:46 PM
navtool.com
09-25-2015 06:21 PM
