New Member here
New Member here
Hello everyone. Just joined the forum today. Going today to look at a 2003 cl type s for the girlfriend. Looked like a good forum to get some info on the cars. After searching around it looks like the main issue is with the trnasmission. This used cl has 50,000 miles so i guess it would be a good idea to ask about a warranty.
Anyways just wanted to say hello.
Andrew
Andrew
Andrew
Andrew
Get a 6 speed and you won't have that issue. Welcome aboard!
welcome aboard and good luck with your CL shopping. If she can drive a stick, I definitely recommend buying the 6-speed. If not, you're still covered for 50k more miles so you should be in decent shape.
thanks for the reply. Needs to be an automatic. And thanks for the warranty info. I did not realize it was covered untill 100,000. Going to look at it when i get off work. I will let you know what i thought.
Got DEP???
Welcome to the forum!
Before you think that the tranny warranty is covered to 109k miles, you need to check the VIN. Not all '03's are covered under the warranty.
Here is a site that you can check the VIN to see if it is covered:
http://www.hondatransmissionsettleme.../php/login.php
said it was covered
i called the local acura dealership anyway to double check on the transmission coverage and they said it is covered for 7 years and 9 months or 109,000 miles (obviously which ever comes first)
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
lanechanger
10-13-2015 10:56 AM
