New Intercooler Heat Exchanger
#41
Just one more picture I took while in the garage getting others. Here are the heat exchnagers when viewed fromt he top with the hood open. You can see the 5/8 inch hose run between them.
#42
Also, one more quick and final update. Today on the way home the OAT was reading 97 for most of the trip. When I got home the water temp was right where I expected it; about 108 F.
The new reservoir is on its way, a 5 gallon fuel cell which I'll mount in the spare tire well.
#43
I just got done finishing up the last part of the new heat exchanger system, the larger reservoir. I don't have complete tests yet but it should work out very well and already seems to keep it cooler. After a breif drive the water temp as within a few degrees of ambient; not bad at all.
This is in the trunk right now and fit in witht he spare cover. I'll make another mount for the spare but since I mostly drive to and from the office, this will work for most of the time and is not needed. If I go on a long trip I'll throw in the spare. But this is prefect for use at the track though. There is a vent so that I can use dry ice in there which should provide a very coold charge. I'll try and test this out soon.
#47
COME AT ME BRO!
so are you not guuna have a spare now??? if so i hope you dont ever get a flat.... anyways looks great scalbert.. buy the way do you have a top mount i/c i dont see a front mount in you pics??
#48
Originally Posted by SCTL-SS
Do you see a way that this could work and keep the spare? Keep the updates coming this is getting more and more exciting.
However, it can certainly be done different. In fact, one of the kits being shipped will use a rear mounted reservoir but be mounted to the side of the trunk. It will use the following fuel cell as the reservoir.
#49
#51
Originally Posted by av6ent
Nice, will the reservoir be part of IC kit and will you provide instructions to install?
