New Intercooler Core
#41
Originally Posted by mrimage27
steve i would love to get it, how much it going to cause me for everything?
http://www.hopesystemsinc.com/intercooler/IC_Main.asp
#42
Originally Posted by types1967
steve your costing me money again damm car parts im going to end up living in the acura hotel!!! lol
Hey, we have been talking about this since over a year ago. All good things come to those who wait.
#43
Originally Posted by 1killercls
I want to see pics of the Intercooler POLISHED!!!
#44
Subie Dubie
Steve, i'm sure you've answered this, but how much HP would the 5AT make to the wheels with the whole intercooler package including E-Manage and 8 PSI ??
Thanks, i can't wait to see the finished product !!
#45
my guess ~ 350whp
#46
Whoa... I didn't know about the N2O option Steve - don't you think the instantaneous cylinder pressure spike (considering it is boosted to begin with) might be disastrous on the factory short block? If you make it a staged N2O system, it might work - this will be something to see!! Cool!
#47
We'll see soon enough though...
#48
That is why I am looking at incorporating the E-Manage into this.
I want to examine the various systems out there and see how I can control a nitrous system to bring it on slowly and then maintain a jetting rate.
With the current manifold, using DP nozzles is perfect and will provide an excellent system capable of serious power. But as you mentioned, it is the shock I am worried about. A ramp up of one to two seconds should provide enough transition period to dull the shock and allow for a 75 - 100 HP shot to be run.
We'll see though but I do plan on having an extra block laying around. Something maybe a bit stronger.
#50
Originally Posted by mattg
my guess ~ 350whp
If so, then the 5AT output may be closer to 320 with the stock exhaust; 330 with a cat-back system
#51
Nitrous has a progressive system... something like Jacob's Mastermind from the old days. Not sure if E-Manage can do that - it works by pulsing the solenoid.
But the hope is to directly control the solenoids with the two additional injector outputs. I would use the ability of the roots blower to provide a linear boost increase with throttle position. With that I will add duty cycle to the additional injector outputs up to about 75% of maximum boost. This would bring it on slowly or rather with the application of throttle. It would be up to me to control the application rate.
This way it wouldn't be inactive in 1st gear on a controlled launch. It could be controlled in 2nd as well, then opened up in 3rd. This is just an idea but one which may work. It also provides the cut off ability at redline so as not to be active if I hit the rev limiter.
#52
Subie Dubie
Originally Posted by scalbert
320 - 330 WHP is what I am expecting, hopefully closer or above 330 WHP. That is also with about 280 WTQ.
#55
The 369 WHP was with the cut-out open.
Also is CLS stock throttle body inner diameter 66mm?
#58
Remember, I made 355 WHP through the stock exhaust pipes. The 369 WHP was with the cut-out open.
#60
that cut out is sweet.
#61
Originally Posted by av6ent
Speaking about a cut-out open, there is an interesting item for sale that allows to open exhaust with push of a button then close when you need it .
Drive w/ Cut-out Open
#62
#64
well 320 whp sounds good.
i'll still have something for them w/ 100 shot jetting.
#65
13.68 @ 102.56
#66
^ what's the update on your car?
#67
13.68 @ 102.56
I'm still waiting on the I/C. The tranny seems to be holding up well. I have the Payntech pulley
w.8.5-9 lbs but without the I/C no serious #s yet. I have hit 7-8lbs(cautiously and fearfully) and at that level several misfires. So no more hard runs(or trailer pulling) until the I/C installed. But I do believe that there is "HOPE" for my car.
#71
#72
!! steve, that sounds awesome!
lol @ camera falling over.
#73
13.68 @ 102.56
Originally Posted by mrsteve
First Guess:
13.3 @ 105
13.3 @ 105
That would be sweet for a 4 door sedan. And if its going to happen only the I/C can make it happen fro me.
#74
Here are the pictures of the new upper manifold. This is a complete unit less the fittings I need to add. This incorporates the changes I manually made to mine to get it to fit but this time it was done on a CNC.
I will be test fitting them on my car this weekend just to be sure. I will also be packaging everything and going back over the literally over one hundred part to be included just to make sure everything is there for the planned shipment of the first two systems early next week.
If you notice, there is a slight difference in hose connections on the IC core. The are reversed where one is at the base and one at the top. I had a change of mind for the flow direction just when the first one was made. But this isn't really a problem as it can be either direction and is also dependant on the type and location of the reservoir.
I also went to studs and acorn nuts for the cover plate to help to dress it up a bit more. The owners can certainly grind the edges and welds down some if they wish to polish it., or maybe powder coat the unit.
#76
i would just like to say... SCALBERT FOR PRESIDENT
