neuspeed short shifter
Texan trapped in NM
Has anyone installed the neuspeed short shifter kit on their '03 CL-S w/ 6 speed yet? If so how is that working out? Did it make a big difference in the cars perfomance? Also, were their any negative affects? Thanks.
Where is my super sauce?
Welcome.
Unfortunately, the search function is not working. There are a number of threads on this device.
Personally, I hated this product for a few reasons. Most folks that had it (including myself) had to trim the shift plate trim with a Dremel to get it to fit. If one didn't trim the plate, every 1, 3, and 5 shift would pop out the cover. Also, I found the resulting shifts way too stiff and inaccurate - so much so that I couldn't effectively downshift in the microsecond that it took me pre-install. Lastly, FWIW, Neuspeed customer service is some of the worst I've seen in a retailer. I'll never do business with them again.
Some folks have liked this product and feel the stiffer shifting is not too much of a trade. I would recommend that if you try it, you drive around with in on for a day or so before you trim you shift plate cover up, just to see if you like it. One thing nice is that if you don't like it de-installing is not much of an issue.
If I recall correctly, the short shifter did effectively shorten the shifter throws by about 25%.
A number of us have installed lowered shift knobs and found that the shifting throws are effectively shorter without compromise of stiffness. I and a few others have a Team Voodoo Titanium ball type shifter. Others have liked Momo Sphere, Shot, and Race ball shaped shifters.
Texan trapped in NM
It probably doesn't matter. I'd ordered it a couple of weeks ago and it is going in on Monday along with AEM pulleys. I'd ordered it long before comptech told me about this forum. At least I know that if a hate it is easy to reverse.
FYI I was pretty sure that it had already been brought up before. I just could find it anywhere. Do you have link to the tread where it was discussed in more detail.
to my understanding it really doesn't make a big difference on the cl, since the cl's shifter is somewhat sort to begin with.
However am going to try one considering they aren't very expensive. But am not expecting to find a difference.
I don't have a link to those threads. Too bad, there was some good information there, both pro & con.
Soopa -- we need the search database back!
For reference, this is what I mean by trimming the shift plate cover. This is the piece that covers the innards of the shifter. I know others said they didn't have to trim as much, but most had to trim something. To me, this means that Neuspeed poorly designed the product.![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
Remember my advice -- drive around without the cover installed for a couple days to see if you like it. If you do, then trim. I made the mistake of trimming before I decided if I liked it.
Good luck.
Good luck.
an adult perspective
um ... search doesn't work? ok, whatever ...
try this thread ... it has the latest on the subject
http://www.acura-cl.com/forums/showt...hreadid=119418
This is the link for my write-up on my frustrations with this product.
Good luck.
Good luck.
Originally posted by brian6speed
No offense Slimey, but i don't think anyone else cut down nearly as much as you have shown in your pic. I barely had to take it down at all and didn't have to touch the clip parts.
I spend a lot of time working with my hands under a microscope -- believe me, I know a thing or two about precise fine cuts and shaves. This product simply did not fit well into my car.
No offense taken. That's just how that poorly designed piece of crap fit in my car. I did not shave that down in one fell swoop, but in many, many increments, probably taking down only about 1/3 - 1/2 millimeter with each shave. I had to take down some of the clip part for the 3 and 5 gear position.
...It just seems Neuspeed didn't think our car was important enough to do the right amount of r&d....
...I dont see how their could be such a big difference from what needed trimming if the parts are exactly the same...
Who knows? And honestly, at this point, I don't really care. I fixed the plate back up so you can never tell what happened underneath once-upon-a-time. My shifts are short enough with the Team Voodoo knob. I've had enough in my dealings with Neuspeed and have made my car Neuspeed free. They are not a customer friendly company (or at least don't have customer friendly representatives - Armel/Joseph) and frankly do not deserve my business.
Just a thought -- It'd be nice if someone produced a short shifter kit that was a transplant of the whole shift lever and not just the added bracket.
I have it installed. Neuspeed redesigned the unit so it doesn't have fitment issues. The early ones had that problem. The new ones don't. The drawback, is the new ones do not have as much of a short throw because of the redesign. For the record I didn't have to do any trimming. It fit fine on my car. As for performance, I really didn't notice a difference. Seemed the same to me. It does add a bit of notchyness, & the throws aren't as smooth. However after a few weeks, I'm able to shift fine. I have no problem downshifing either.
Swim Bike Run...
Originally posted by fuzzy02CLS
...As for performance, I really didn't notice a difference. Seemed the same to me. It does add a bit of notchyness, & the throws aren't as smooth. However after a few weeks, I'm able to shift fine. I have no problem downshifing either.
I personally thought the shifting was night and day different (better). It felt much shorter to me. My shifts weren't quite as smooth as before, but I was willing to make this trade-off given the short throws. My brother-in-law, who only occasionally drives my car, also noticed a significant difference in the short throws.
I guess with this product it is especially true that YMMV!
Texan trapped in NM
Well everybody it's getting installed tomarrow by professionals. So hopefully if thier are any bugs they'll get it worked out before I pick it up. I'll get back to everyone and let you know how it turns out. Thanks for the insight.
![Crazy](https://acurazine.com/forums/images/smilies/crazy.gif)
It's only slightly harder then putting gas into the tank.
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
Texan trapped in NM
it's getting done along with the pulleys....it's kind of a package deal. I'm not paying much at all for them to do it. To me it's worth it because if they screw it up it's their ass.
Texan trapped in NM
I've been impressed with the shifting feel so far. the shifts are clean and crisp. the only down side of the short shift kit it is when the car is cold it's a bit tough to get it into first gear. it's no biggy once the car warms up. also, the guys who installed it didn't have to trim the shift cover.
does anyone know how to post pics in a thread? it says that the max size is 1 byte for attachmends. 1 byte isn't jack. how am I going to get anything down to that size. i tried setting up a online photo book but they all require a log in for anyone who goes to the link. any help would be nice. thanks.
Cost Drivers!!!!
spoiler900
10-10-2015 06:48 PM
guyvelella
09-30-2015 11:02 PM
