Need help with sport shift light going out
I'm a reader not a writer
Over the weekend, my sport shift light starting dimming. Than it disappeared, came back, and disappeared for good. I have done a search on this and got tired of reading over 30 minutes worht of threads with no success. The repair manual has a few tests to perform, but besides jiggling the connection to the "pcm"? (the brain box under the coin tray the only other fix was to replace the console. Does this mean the entire guage panel (tach, speed, gas, etc.) Any help would be appreciated.
thanks
larry
thanks
larry
Help needed still
Found that my select light is out also, from the select/reset buttons, clock light is also outm and the auto and off buttons from the climate control is not lit either. I checked all the fuses last night and they are fine. Before I noticed the other lights off, i took apart the dash and the light for the gear indicator was fine. Any one with any suggestions?
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
