Need help with head lamp moisture.ASAP
Old 03-25-2009 | 01:16 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
I finally installed my lights.Only problem,I put moisture in my parking light and dirrectional spot.it just got done rainning and put my car togther blubs were wet and I didnt pay attention.there was a moisture dot the size of a eraser.figured it would go away.I lite the lights to make sure they were working and the 2 spots totally fogged up.Now......Can I leave the blubs out for the moisture to escape or do I need to reopen and clean out????????
Old 03-25-2009 | 02:40 PM
gnuts's Avatar
3.5 psi
I used to have moisture bad in my one headlight. If you take the bulbs out and spray some air in there (if you have a compressor) it helps. You can also take the bulbs out and drive around (in nicer weather) to vent them a bit. I don't think you need to go as far as re-opening the lights tho.
Side note: i think that drive through car washes put the moisture in there. I think it was the force of the spray, but i've never gone back and i've never had the problem again.
Old 03-25-2009 | 02:54 PM
I took the blubs out for a hour and there completly clear again.I'm just gona leave them out longer to make sure.
Old 03-26-2009 | 12:19 PM
MrFluffy's Avatar
To many cars in my garage
I had that problem when I did mine similar any ways mine totaly went away( I think a side effect of the ccfls is they are hot so if there on long enought they will heat the moisture and then it will disipate?)
Oakroadsteve
10-28-2015 10:28 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Eggs999bacon
09-24-2015 10:08 AM
Quick Reply: Need help with head lamp moisture.ASAP
