Need a 12V (battery) lead from the ignition harness... anyone?
anyone know the color code of 12V constant and 12V ignition?
its just going to be something small, maybe 3amps or less. 14-16 gauge wire.
look in the driver side fuse panel...theres something listed as accessory or something...thats what i used for my remote wire for my amp kit on my stock radio it only gets 12v when the ignition is on good luck...if you cant find it let me know and i will look up the exact fuse slot tomorow...its 2am here and im hitting the sack
if its a small wire i.e. remote wire for stereo or something like that just pull the fuse out of the spot you wanna tie to and strip the wire back and stick it in the hole for the fuse and put the fuse down on top of it...
12volts = white
Starter = black/white
Ignition = black/yellow
Second Ignition N/A
Third Ignition N/A
Accessory = yellow
Second Accessory = white/black
These are all the ignition harness wiring colors. I would suggest taping into these wires instead of any random wire under the dashboard. Tap into the wrong wire and there goes your airbag or computer. Hope this helps
Second Ignition N/A
Third Ignition N/A
Accessory = yellow
MrHeeltoe
20
02-23-2023 01:54 PM
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
