My thermometer doesn't give an accurate reading
3rd Gear
I just bought an Acura CL-S, all white, 2001 model. It's two days old. I love it!
But my outside thermometer gives rather erroneous readings. It is some 5-6 degrees warmer than the actual outside temp.
Where is the temperature sensor located? Is it really reading the paving below, or the outside temp?
How can I have it fixed?
Ambidextrous Masturbator
You can adjust the reading... do a search on this site because it has been discussed before.
Also, check the FAQ in my sig.
Welcome to the board!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
check this link: http://www.geocities.com/~gamesmgr/chod/acura/#Dash9
also read here: http://www.acura-cl.com/cgi-bin/ulti...c&f=1&t=005266
The outside temperature sensor is in the front of the vehicle, just ahead of the A/C condensor. The sensor is about 12" above the road surface, which may influence it's reading (dash indicated temperature above the "bank sign" temp.). Also if the vehicle isn't moving the heat radiating from the coolant radiator and A/C condensor will influence the dash temp. readings (higher).
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
