Mugen T-Stat and Fan Switch installed
Old 06-11-2004 | 02:33 PM
  #41
mantis23's Avatar
Moderator Alumnus
Originally Posted by scalbert
King Motorsports:
http://www.kingmotorsports.com/
Don't bother looking up the parts under CL as they are not listed. Just call them and order these part numbers.
THERMOSTAT 19301-XGMR-0000 $69.00
FAN SWITCH 37760-XK5-00N0 $45.00
RADIATOR CAP 19045-XGER-0000 $29.00
ordered
Old 06-11-2004 | 02:34 PM
  #42
RUF87's Avatar
Lead Footed
OH BTW, don't forget to make sure the gasket lines up correctly when installing the new one. There's a little rubber tab that needs to fit properly in the engine block or you will have a small leak . . .
speaking from experience :o
Ruf
Old 06-11-2004 | 02:35 PM
  #43
RUF87's Avatar
Lead Footed
Originally Posted by mantis23
ordered
Great!
So you are in for the mod and Chopper . . anyone else?
The more the merrier
Ruf
Old 06-11-2004 | 02:36 PM
  #44
Smitty's Avatar
Ruf
I do not advise you use the MUGEN gasket that comes with it.. I recommend you take the gasket off of your stock piece and put it on the Mugen Thermostat... the rubber gaskets are different!!!!!
Old 06-11-2004 | 02:38 PM
  #45
RUF87's Avatar
Lead Footed
Sorry, yes, that's why I had the leak . . I remember now that the one on the new tstat is different and I had to take it off and put the old gasket back on. I've replaced tstats for many of years and just installed it with out reading or looking everything over. :o
Ruf
Old 06-12-2004 | 10:27 AM
  #46
babyblue's Avatar
Sold but not Forgotten...
dont mean to get off topic but has anyone tried the same things from spoon? Cuz my dealers doesn't have the mugen stuff here... Will have to wait till July and order them to my coz house in NY...
Old 06-13-2004 | 10:03 PM
  #47
blader's Avatar
Audi S4 driver
I also ordered the parts .. should be here thurs. hopefully unichip will too ..
Old 06-14-2004 | 01:57 AM
  #48
BlueCLS6's Avatar
ex 6 Speed owner :(
Do you think not getting the fan switch and only running the low temp thermostat will cause too much thermal cycling of the engine block? From what I imagine, the only time the fan switch is needed is when the car is not moving. Is the fan switch critical?
Old 06-14-2004 | 06:37 AM
  #49
scalbert's Avatar
Yes, it really should be done in conjunction. At low speeds the engine temp would remain at or near the factory setting since the fans would only cycle between 205 and 195.
Old 06-14-2004 | 12:48 PM
  #50
blader's Avatar
Audi S4 driver
Steve what does the mugen stuff keep the engine at? exactly 180 I think I read somewhere, right? and the stock stuff cycles between 195 and 205 I guess?
Old 06-14-2004 | 12:50 PM
  #51
scalbert's Avatar
Correct, my engine coolant temps vary between about 175 and 185. The stock was between about 195 - 205.
Old 06-14-2004 | 04:24 PM
  #52
rchavis's Avatar
Humm. this sounds good. Any change in gas milage?
Old 06-14-2004 | 04:30 PM
  #53
darrinb's Avatar
///M POWER
i wont hit the track on the summer w/o this mod
Old 06-14-2004 | 04:46 PM
  #54
blader's Avatar
Audi S4 driver
I wont hit the track in the summer period. even if your engine is running cool, your still sucking in hot air.
F-C
Motorsports News
28
09-25-2019 07:40 AM
01CLOwner
10-09-2015 01:07 PM
Iakonafuji
09-21-2015 02:39 PM
NSolace
09-03-2015 08:02 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Mugen T-Stat and Fan Switch installed
