MDX parts swap...LSD...higher stall convertor..ect.
well i was looking at some specs on the MDX and...i think i may have found a winner...im almost certain the diff will swap right in...also...im wondering if the MDX because of being a truck and able to tow would have a higher stall convertor...on a side note...the techs said theyre doing MDX trannys now too....
Bleed Honda Blue
Are you sure MDX has LSD in the trans for the front wheels? We had less than 10 MDX trans problem since the introduction in 01. It is nothing compare to TL and CL, we had almost 200 last year! Hell I think we had less MDX trans than RSX engine swap(blew up because of over reving).
Originally posted by scalbert
Why not just swap the whole trans and go AWD with the VTM-4 system.
I just wish that the VTM-4 transfer case was not intergral to the transmission.
