mdx cams
I would have to agree, the MDX cams are probably be designed for better mid range torque in mind. They would probably make the top end suffer noticeably.
Originally posted by typeR
how about NSX cams? would they work?
i was affraid of that...im thinking of seeing what would happen if i stayed on the high rpm side of my cam all the time...i know logic would say i would loose low end...but its worth a try...theres a big serge when i hit 5500...im thinking this 3.5 looking for more air?....any way scalbert of making it stay on ,the high rpm side...with out an s afc???its vacuum driven isnt it?
Do it! U Only Live Once!
The MDX cam doesn't have as high a lift creating more mid range torque for pulling heavier loads because it's a truck. This also keeps the idle smooth as well.
But there are two problems with this concept. First is that you also need to adjust fuel and timing accordingly for the high lobe. The other is that you don't want to run the high lift lobe down low, it would hurt power not to mention the idle would be crappy.
VTEC actuation
As long as there is oil-pressure you can actuate the VTEC solenoid manually. We used to do this on the Frankenstein motors of yesteryear. Integra LS block with a Integra GS-R head - essentially a larger-displacement GS-R motor running carbs.
On my civic I had a SPOON VTEC-controller which allowed me to set the VTEC actuation from 1500rpm to 7500rpm.
Is there any cams ?
i just finsted porting and polising heads and intake picture to follow and dyno sheets results were bad 10.8 hp gain 6.5 torqe gain i want more hp without NOS.
John
John
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
ExcelerateRep
10-14-2015 08:20 AM
