Manzo headers review
I just finished installing these headers and figured it may help someone in the future:
Manzo 6 2 1 Sport Manifold Exhaust Header for Acura 01 03 CL TL Tpye s 3 2L V6 | eBay
I took a chance on these after searching and searching for the Comptech headers and couldn't find them. Anyway......the fit and finish was pretty good although the welds could have been better. I grinded down some on the welds on the inside of the tubing to help air flow. The tubing itself on the J-pipe seemed a little thin but for the money what do you expect. The bend in the rear header was perfect for my 6 speed mount. I had about an 1/8" clearance. I had no problem whatsoever with the install. All together I am impressed. The power increase that everyone talks about is diffinetely there. I would purchase them again if I ever needed to. Hopefully I don't but time will tell if they stand the test of time.
It took me a while to purchase them. I just couldn't find the XS. It took me even longer to install them. It had to be 6 months. I was just so unsure.
There is likely zero difference in any of these headers other than the actual Comptech units. They are all likely produced in the very same factory in China and just packaged in different brand boxes to give buyers some semblance of legitimate product offerings. I'm not knocking these at all, I have some "SR-S" headers myself (obvious RS-R name association).
At various points in the production of these things it seems they have gone back and forth between producing them with and without the bend necessary for the 6-speed guys, but that seems to be the main difference. If you can come to Dallas and show me that your "Manzo" headers have a different collector diameter, primary length or steel grade than mine, I'll buy you a beer.
Again, they're decent for what they are. I don't like buying obvious rip-offs, but Comptech isn't making headers anymore so I'm not taking any business from them. I also don't need to be CARB compliant. These suit my needs just fine. But I also don't think there's any difference brand to brand and to refer to them by branding just gives rip-off Chinese companies legitimacy in their practice of ripping other companies off.
Are the primary tubes coming off the heads 1.5" like comptech or larger?
Kind of want to get a custom set of header manifolds in around 1.6" diameter with longer length tubing and a true merge collector.
I keep saying that the first company to make a set of headers for the 1st generation J-series guys that matches up with the J-pipe from a '03-'07 Accord V6 or '04-'08 TL is going to do very well. Between the current length of aftermarket headers available to us and the height of the flange where the aforementioned J-pipe sits, there are about 4 inches of space. If someone took that space and made longer primaries with a true 3-1 collector it would make gobs of power more than even the current aftermarket headers do.
I've asked Prank Parts about it before and he said that he had considered it, but didn't see it getting off the ground any time soon. If a bunch of people pestered him about it, though...
I don't disagree that they are all from the same place. These are readily available unlike other brands.
I never even measured. I had to clean up some of the welds. So far so good though.
I just don't think these companies understand the market size. The Civic/Integra guys who swap J-series usually always pick up a J32A2. Even still, you have the entire 6th generation Accord V6 market as well as all of the CL/TL guys. You'd even have 1st generation CL guys buying them!
If there's a market for the current off-brand headers, there's a market for better ones. Admittedly, the cost that these would have to be marketed at would make for a smaller market, but it's still there. I bet 50 sets would be sold, easily. Recently, I participated in a group buy for the Vibrant H22A header for my Accord. We were told that we would need a minimum of 75 orders. We got well over 100! That was a $500 price point. If you made J-series headers that had good bends and true collectors, I'd be all over it. Run a factory Accord/TL J-pipe for emissions testing and get your pretty RV6P v3 J-pipe for everyday. Done.
Even if a company agrees to make it, they don't like using real merge collectors because of extra cost. Most buyers don't know the difference and aren't willing to spend extra on the collectors.
Since I want quality stainless and real collectors custom is way to go.
Here's a thought. Since custom is the way to go....and I agree with you. Wherever you get yours done. Let's try a group buy. I mean they will have already made a set.
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
