look what i found
Old Jan 30, 2010 | 05:21 PM
Rajca's Avatar
wham bam thank you ma'am
look what i found
http://www.nolimitmotorsport.com/prod/HON-220-580-1618F
damn expensive but cheaper then having them custom made. added on to list.
have pistons picked out (kms) but dont know if they will change the compression ratio or not
and someone is working on making cams
Old Jan 30, 2010 | 05:42 PM
friesm2000's Avatar
B A N N E D
but sadly they are not for a J36
Old Jan 30, 2010 | 05:47 PM
Rajca's Avatar
but their is pm nva-av6 i think its either the 3.5 or 3.7. not cheap
Old Jan 30, 2010 | 05:55 PM
friesm2000's Avatar
B A N N E D
yeah, i seen rods for the 3.5/3.7 before for sale, but sadly i can't do it anytime soon , so no need for them currently
Old Jan 30, 2010 | 06:34 PM
Rajca's Avatar
do it once and do it big. no point of doing 3.6 then later 3.7-3.9??????????? just save up and do it all at once.
Old Jan 30, 2010 | 06:36 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
They are definitely expensive, but would also be nice to have.
Old Jan 30, 2010 | 06:44 PM
friesm2000's Avatar
B A N N E D
my motor is still good , and will be for a LONG time, has had 3k oilchanges since it was new
but it may not be once i get my lazy ass to install my
but yeah best to do it once, and be done with it
Old Jan 30, 2010 | 08:43 PM
SPoolinspOON's Avatar
OG 3.x^7 rawr
go big or go home
Old Jan 30, 2010 | 11:31 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
Old Jan 31, 2010 | 12:04 AM
OperationDarkie's Avatar
Ultra Negro
Where is this j36 coming from? I have not heard of a J36.
Old Jan 31, 2010 | 12:08 AM
civicdrivr's Avatar
Its a prototype that Honda commissioned for use in the next space shuttle. They paid me millions of dollars to test it for them.
Old Jan 31, 2010 | 12:11 AM
friesm2000's Avatar
B A N N E D
^^hybrid motor; like the lsvtec hybrid
for the j36, it is using the j37 crank and rods, then the j35/j32 pistons for the motor to be a j36
Old Jan 31, 2010 | 12:20 AM
civicdrivr's Avatar
Ummmmm.
J37 crank.
J35 rods and pistons.
Old Jan 31, 2010 | 01:06 AM
DC3328's Avatar
Your Garage
any extra work involved compared to the now inferior j35 swaps? (j35 crank and rods, j32 pistons) or is it still "plug and play" if you will
Old Jan 31, 2010 | 01:08 AM
Rajca's Avatar
J32a2 all the wayfor me at least.
Old Jan 31, 2010 | 01:11 AM
DC3328's Avatar
Your Garage
J32a2 with large turbo and nitrous all the wayfor me at least.
fixed
Old Jan 31, 2010 | 01:20 AM
Rajca's Avatar
J32a2 with large turbo and nitrous, possibly sc? hmm all the way for me at least.
Originally Posted by DC3328
fixed
fixed again
Old Jan 31, 2010 | 09:53 AM
OG 3.x^7 rawr
J35 build is plug and play..as with the J36 and J37, the J37 crank is used so the snout is shorter which you will have to use some brain cells to get it to work right
Old Jan 31, 2010 | 12:10 PM
Ultra Negro
No I mean I am trying to understand, why call it a J36, when it is a J37, using the crank out of a j37, with j35/32 pistons is still a j37, because of the crank displacement.
So yeah as far as I know it is not a J36.
Old Jan 31, 2010 | 12:14 PM
friesm2000's Avatar
B A N N E D
cause the total displacement is 3.6 liters so thats what the 36 means
also the J37 has a 1mm larger bore then the J35/J32, which makes up that last 0.1 liters of the displacement
Old Jan 31, 2010 | 12:35 PM
Ultra Negro
Can you show me the calculations? or a link towards it?
I would like to see for myself
Old Jan 31, 2010 | 12:42 PM
friesm2000's Avatar
B A N N E D
try http://en.wikipedia.org/wiki/Honda_J_engine for the specs, then just find a displacement calculater
Old Jan 31, 2010 | 12:53 PM
friesm2000's Avatar
B A N N E D
also the number are not exact for Honda's rated displacement either(they are actually a little overrated in size, but if you did round them off, they would be correct though)
Mike734
Dec 10, 2021 01:25 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
Bielikb96
Sep 28, 2015 10:45 AM
STL TL-S
Sep 23, 2015 08:52 PM
