Lip Kit DIY
This is a DIY for the TL lip kit. First off I want to say that this project takes time, patience and attention to detail. If you don’t have all of that, don’t start this project. Ideally you’ll want the car off the road for a while because you’ll have to remove bumpers. This is the way I did the kit. Some have taken slightly different approaches, but the end results are the same. I had no experience prior to this project and i'm not claiming to be an expert at body work. Again this is just how I did the project and others before me have done it. Hopefully this is helpful for people trying to do a similar project.
Materials I used: 3M 8115 epoxy to hold the lip on - you'll need a lot of it…(8tubes). Ebay had the best deals I found for multiple tubes. Then I used Polyflex (flexible bondo) to fill any gaps (one jug with hardener). Whatever you use it needs to have some flex to it. Always wear the proper masks when using these products, as some are toxic. Gloves may also be necessary. FRONT:
SIDES:
REAR:
NOTES: Take your time and triple check your measurements before cutting and before epoxying the lips on. Use a small drywall spreader to spread the Polyflex. It’s similar to doing drywall mudding. Fill the gap and spread it over an area a few inches past the gap. cltypeSLOW (& Distored) Summer project https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/full-molded-tl-lip-kit-cltypeslow-summer-project-488555/ evan03CL rear lip https://acurazine.com/forums/2g-cl-photograph-gallery-53/acura-tl-rear-lip-project-bumper-removal-diy-711869/ evan03CL front lip https://acurazine.com/forums/2g-cl-photograph-gallery-53/evans-tl-kit-thread-diy-summer-project-494154/ |
nice write up. i see alot of tl kits coming soon.
wheres the pic of the end result?
Only two decent shots i have so far:
http://img406.imageshack.us/img406/4231/lip5006.jpg http://img406.imageshack.us/img406/9791/lip5002.jpg |
Thankyou sir :thumbsup:
damn so nice
you are the man Andrew!
good writeup!
lookin hella nice, im jealous of u guys having the better lookin kit lol
Very well done!
Thank you for taking the time to write this up :thumbsup: |
nice write up. thanks.
time to get to work. |
what do you think about the rear wingswest lip? Its a little bit thicker how close is the tl lip to your mufflers?
i'm using the Wings West front lip. I just cut off the part on the sides. I believe pdiddy is using the WW rear. You'll most likely have to trim off part of the underside, but you can't see that once it's on the car. I'm going to weld on some circular tips soon because the CL tips don't match right and are tucked back too much now.
wonder if the 2nd gen TL comptech exhaust fits since it sticks out a little further you might not have to modify the piping. Looks great gnuts, i was planning on running the wings west front and rear and go with the oem sideskirts
Originally Posted by gnuts
(Post 11962522)
oh i thought you had the WW rear diddy. What size are the tips on your HKS? I was thinking of getting some 3.25" circular rolled tips.
The WW rear would work too, it's just a little bulkier than the OEM TL lip. |
well i did state a while back that i had the WW rear but it was the oem i just forgot cause i hadnt look at it in a while.:tomato:
i think their 4 inch tips id have to check. |
Originally Posted by p.diddy
(Post 11962888)
nah i got the oem rear. i knew i was going to have the issue of my exhaust sitting too far back with the rear lip on so i went to a muffler shop and got my exhaust extended out to be flush with my lip.
Honestly I could even tell you. I changed them out so long ago I don't remember. I got an idea though. Go to brianlins thread and check out his pics. He has comptech exhaust so you'll be able to see what it will look like with the kit.
(Post 11959166)
^lol it does.
i know, he had C2's and i have C4's....and he had custom grey paint i think too. His ride was inspiration for sure.
Fr the exhaust tips i would say something between 3.5 to 4 inches is ideal. The ct mufflers are 3.5 and look a little too small where as the hks is 4 and looks too big, so maybe a 3.75 would be perfect. Wonder how it would look with the ww front lip with ronjon sides and rear, or do you think you need the flow of the tl skirts to make it look right. On a side note does anyone know if the ct mufflers have always had 3.5" tips or did they use to be 3". just seems like older versions look smaller to me.
Originally Posted by brian6speed
(Post 11966541)
(Post 11966561)
i think the full kit would look better instead of mismatching kits.
Kyle7777 has the 03 TL front and versus sides and rear and i think it looks nice.
Are comptech tips really 3.5"??? They look way smaller than that. I agree i need something bigger then the comptech tips. |
(Post 11966635)
^ lol
Ill verify that the CTs are 3.5". |
i just got a quick ? as well sorry if it jacks the thread but would a tsx front lip anywhere fit a cl? i kno itll be custom fit as well as the tl lip into the cl.
can i ask you somthing, how much epoxy tubes did you use (just for front lip and rear)
God damn I love those lip kits! Way at the bottom of the wish list right now, haha. Great work man, looks insane!
Originally Posted by LUTHOR-CL
(Post 11968511)
Originally Posted by duyx817
(Post 11969513)
(Post 11970223)
I see people asking all the time now if this lip or that lip will fit. No one has done a TSX lip on a CL, so if you want to experiment, you're sort of on your own.
The tubes are pretty small, they look like two mini caulking tubes attached to one another. I think i used 8 tubes total and i know i used one tube on each side. So i probably used 3 tubes for the front lip alone and another 3 for the rear. oh ok, ill try to be the first i guinea pig i guess lol. and thinking of flat blacking the whole car as well. |
(Post 11970223)
The tubes are pretty small, they look like two mini caulking tubes attached to one another. I think i used 8 tubes total and i know i used one tube on each side. So i probably used 3 tubes for the front lip alone and another 3 for the rear. |
Thanks for the contribution. Much appreciated. :thumbsup:
(Post 11971783)
god damm.. each tube is like 45 dollars
nice writeup
Looks like a future mod :biggrin:
