lip for CL 2g
Old 02-10-2014, 01:37 AM
3rd Gear
CLj32GUY's Avatar
lip for CL 2g
what lip can i put on my CL?
ive heard the 3g TL fits?
is this true...
Old 02-10-2014, 08:25 AM
3.5 psi
gnuts's Avatar
no. 2nd gen TL with modification. so some searching. Lots of info on that topic.
Old 02-10-2014, 07:11 PM
ryan10's Avatar
What Lip kit did you use? Can you leave a link on where you got it from please.
Old 02-10-2014, 07:26 PM
3.5 psi
gnuts's Avatar
Mine is a 2nd gen TL wings west front, modified to fit. By modified I mean cut into 3 pieces and moulded to the bumper, gaps filled. I cut the flares off the sides.
Old 02-11-2014, 03:55 AM
3rd Gear
CLj32GUY's Avatar
Cool! Thanks for the info. Hope I can get it to work.
Old 02-11-2014, 11:32 PM
sergiu's Avatar
U can use ron jon lip if u can find a used once I have the side skirts that I kept after the crash
Old 02-13-2014, 08:07 PM
Gatorx's Avatar
goodness gracious
Old 02-19-2015, 02:14 PM
CL SpeedsteR's Avatar
I'm wanting to do the WW rear from TL on my CL, know anyone that's done it?
Old 02-19-2015, 03:03 PM
3.5 psi
gnuts's Avatar
no sorry, but it's just beefier than the regular aspec. and has exhaust cutouts. Getting it to fit would be the same deal. You'd just have to make sure the exhaust cutouts line up with yours or have your muffler tips modified after. the WW lips are super bendy which helps.
Old 02-19-2015, 07:46 PM
DLntheCL's Avatar
that is the one i used. instead of cutting it into multiple pieces, i just cut the excess of the 2 ends off at the wheel wells and epoxied the backs back on.
Old 02-19-2015, 09:35 PM
right, its polyurethane which helps, thanks.
hows that WW front fit? I'm running 99-01 TL oem, frowns from certain angles, hate that
i knew someone had done it before.
how much did you have to cut?
how did it fit along the back of bumper?
any pics of fitment before you molded it?
i visited your other thread, looks good in white...
Old 02-20-2015, 08:10 AM
DLntheCL's Avatar
probably 2 inches or so cut off flush with the wheel well, i cant remember. i started in middle of rear and tacked it on with screws to hold in place as i went around the corners. once your satisfied everything is even then sharpie the line onto the bumper so you know where to place it when you permanently attach. once the end caps are off, as i said cut off the little tab part and put that back on the rear lip to give it a finished look. here is a few pics
https://acurazine.com/forums/photogr...-build-877419/
teh CL (02-22-2015)
Old 02-20-2015, 08:11 AM
3.5 psi
gnuts's Avatar
the WW front I cut into 3 pieces and filled the gaps. I can see how DL fit the rear as my gaps there weren't that big, but in the front there were some decent gaps. Fill those gaps with material you cut off the sides skirts.
Old 02-22-2015, 03:17 PM
Thanks I took a look at all your threads before asking as I was hoping to get some shots before you actually molded it plus some of those pics were a bit blurry when I tried to zoom in, but thanks anyway I pulled the trigger 2 days ago, I'll post some pics up after I install it
Hmmm yeah thanks I see DL does his own body work and I guess you do too, but I dont, I'll do a test fit maybe but that's it so thanks anyway I'll post some pics after
Old 02-22-2015, 09:47 PM
teh CL's Avatar
how have I never seen this car?
calrow
05-03-2017 10:21 PM
jmaxima03
09-27-2015 10:22 AM
spoiler900
09-23-2015 04:41 PM
Quick Reply: lip for CL 2g
