Killed my clutch tonight at the track
As the subject says I killed my clutch tonight. Its slipping hard and needs to be replaced ASAP. What are my options and where can I get them from. HELP!!
Moderator Alumnus
http://www.acuraoemparts.com/delray/...CL__CLUTCH_SET
pressure plate and clutch for $235 wow, anything else i need?. Wish I could get a lightend flywheel to
Blown is Best
Don't forget to use the discount codes on this thread:
http://www.acura-cl.com/forums/showthread.php?t=187633
Depending on the shape of your flywheel, you may need one of those also. Items to replace when you do your clutch:
- Release Bearing
- Pressure Plate and friction disk
- Rear Main Seal
- Pilot Bearing possibly
- Flywheel possibly
- Release Bearing
- Rear Main Seal
- Flywheel possibly
this sucks because I can order a spec clutch kit for $557 or oem clutch kit for $269. A new flywheel will cost $300 something, but I wont even know if i will need one until they open up the tranny. Just going ahead and ordering the flywheel wit the clutch will cost me like clost to $1 grand getting the spec clutch and OEM flywheel, but only $662 getting the OEM clutch kit wit the OEM flywheel. Top it off if I decide to just order either clutch and take the risk that the flywheel is still good or bad, if they open it up and see its bad, then I got to have the car sit in the shop for a few days for a flywheel then I have no transportation. Lol, this is a big predicament. Since this stock clutch lasted to 90k im leaning towards just getting another once since they seem to be pretty strong, just dont want to spend that $300 on the flywheel if I dont have to.
Spend the $300. It isn't going to cost you any more in labor and I pretty much guarantee you're going to need a new one. Also due to the dual mass design we can't resurface the flywheel.
Originally Posted by gc86
I remember reading somewhere that the SPEC clutch kit is just an OEM painted unit?
i cant take this burt clutch. Driving at slow speeds because if I go too fast the clutch will slip. People behind me get mad and come from behind me and jump infront of me fast without signaling or anything.
Originally Posted by spdy0001
why don't you learn to take care of your shit?
take care of my shit??? im the second owner of the car and its the original clutch wit 90k on it. Do you even have a 6 speed?
Originally Posted by All Mine
I thought I read some where that this is your second vehicle? Why don't you drive the other one?
SidhuSaaB
05-30-2020 12:40 AM
