K20 Acura RSX-S Fuel Injectors & S/C
Lives On BOOST
I have a question regarding the rsx fuel injectors and the hbp s/c. I was considering getting the k20s off a member in the bm, but I dunno if I can run stock fuel injectors on a hbp or would I need to upgrade. I think siggy did it on his swap, but I wanto know if I really need them?
THE J35A2...
not sure if rsx will fit on J32...
we need something like this Okada Ignition coils but it's too expensive and we don't have something for J engines
MSD make a similar product for DIS, but also not sure if it's gonna work...
SOLD
I think there is only a certain amount of tuning you can do before you reach a plateau where injector upgrade becomes almost a necessity, especially with HBP. If S2K injectors have higher flow and are guaranteed to be compatible, why not go with them? I am sure you can find some for less than brand new cost somewhere.
Lives On BOOST
Originally Posted by SIRSIG
s2k 360cc flow rate @ 43 psi
Then there's my kit, tried and proven and in excellent shape. People always try to save a buck, but in the end, disaster, take a look at the vvv666net site, logans old kit. seems it was a complete failure and waste of money. Mine, you just bolt on and go. And you can thank allmotor for that. look here... https://acurazine.com/forums/showthr...hlight=thinjim
THE J35A2...
THE J35A2...
anyone know where I could get some s2k injectors?
THE J35A2...
hey siggy, should i just post in bm section or is there another place i should look
Lives On BOOST
found some on ebay, but there are only 4: http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
THE J35A2...
THE J35A2...
would I need 2 more though?
Originally Posted by typeR
r u kidding ...no itll be just fine to run 4 cylinders rich and two lean...come on
SOLD
Unless you want your engine to
Blown is Best
i shouldve known better, i need to run a couple cylinders lean
SOLD
Originally Posted by NightRider
NO what we mean is you will need 6 S2K injectors...since forced induction pushes more air into the engine, so to compensate you need more fuel. 2 less injectors would provide you with less fuel.
Lives On BOOST
Originally Posted by Allout
You can always buy another set of 4 and sell two to someone doing the same as you. Shoot me a price if you end up with two extras.
Lives On BOOST
sig, how much did you pay for your injectors? The place on ebay is trying to sell me 6 for $529. Is that a good price? I had no luck w/ the forum, but if I went w/ samir's rsx ones what would be the downside? Their only like 60 compared to 529
2600lb CL
It's not magic, throwing in larger injectors doesn't guarentee anything except that the ecu will shorten the pulse of the injectors because they are larger.
Big injectors = ecu shortening the pulse
stock injectors = ecu trying to lengthen the pulse if needed
Pulse = the time that the injectors stay on spraying
All you need is a piggyback and a good tune. That will help whatever problem or fear you're having of running lean/rich/or whatever it is you want.
Stock ecu's will always compensate for whatever it is you throw at them.
Tuning is everything.
THE J35A2...
not yet, still need to install the s/c & get tuned
Lives On BOOST
with what? cause you should really be OK with stock injectors for now if you'll just boost it to 6psi, that ofcourse with e-manage tuning imo...
SOLD
It's always good if you are going to run HBP to Emanage tune and take it from there, it may be fine...better than wasting money on injectors if you don't need them for your setup
THE J35A2...
so what your saying is that w/ the emanage I should be fine running the hbp w/ stock injectors
dude, seriously...
you can use your stock injectors using any type of piggyback, even with comptech's ESM, the only reason why most people use the blue e-manage is that it's proven to work with j32 engine real well and they get more out of it
with the ESM you are limited on tuning and basically will push your injectors to death.
with the e-manage it can have a total duty cycle of around 80% at 6k RPM which is safe and you can still have more room for improvement (power)
BTW, i'll let you know if i still have my HBP...
