Just had tranny replaced at 108k and......
Old 07-27-2007, 09:46 AM
5th Gear
wmattia's Avatar
A month ago my 2003 CL-S started "fish biting" (bucking while accelerating between 30-40 and 50-60mph. I brought it to Acura and they covered the tranny and they did my timing belt / water pump for $900.
The problem is still there, It will always start kicking while accelerating from 50-60ish mph. I can push the petal down harder and get up to 65mph and it goes away. I also have a rough idle (rpms go up and down).
I am going to replace my plugs, battery, and clean my air control valve this weekend. Is there anything else I should be doing?
Thanks,
Bill
Old 07-27-2007, 10:49 AM
Zippee's Avatar
Take it back to Acura before you screw around with it. If it's the tranny they should cover it.
Old 07-27-2007, 10:59 AM
fuzzy02CLS's Avatar
IAC problem
It's the most common, giving the symptoms of bucking, stalling or RPM shuddering.
Old 07-27-2007, 11:12 AM
5th Gear
wmattia's Avatar
Originally Posted by fuzzy02CLS
IAC problem
Thanks guys for responses.
Fuzzy,
I'm going to give it a good cleaning and if that don't work then I'll replace it. Do you think I should just skip the cleaning and put a new one in?
If that does not do it then I'm gonna go with Zip's suggestion and call my dealer up on Monday and play the tranny card again.
Yikes
05-03-2021 04:29 PM
cm561
01-27-2016 10:17 PM
niray9
12-08-2015 07:34 PM
01CLOwner
10-09-2015 01:07 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Just had tranny replaced at 108k and......
