just did seafoam o.O
None
i just put in some seafoam in the vac line and no smoke came out after the process? is this typical or is something wrong? any info is appreciated, thanks!
It should have smoked.
None
Originally Posted by CH46ESeaKnight
This might sound stupid but, You did have the engine running at the time right? You did not just pour it in to the line.
Hi.. I just bought a pint of sea foam motor treatment.
but I don't know which line to suck in to the engine.
can anyone show me some pic about it?
I deeply appreciate that
Don't Mess With Texas
and oxiclean goes in what? o.O
im doing seafoam because of the all positive comments about it..
haha, yeah ... maybe i put it in the wrong vac line or "tubing" ... lol i doubt it though.. i put it in this http://reg.imageshack.us/content.php...mg25692zm5.jpg (click image, bottom left.)
I just did mine yz2day and yes it makes a big diffrence, especially with ur revs, itz a lot smoother and faster.
did u run the engine 4 abt 15 mins to get it hot or warm b4 u put the seaform thru the line ? ( i drove mine hard for 25 mins b4 i run it tru)
let it cool dwn for 10 & run it tru the line (by letting the car suck it up)
waited another 15 mins for it to soak up and then started the car up, let it stabilize or run for a min or so
then time to drive (as soon as i turn the key afta the 15 mins wait = lot of white smoke for about 15 mins) while i drive it hard rev to 5k several times.
good stuff i tell u.
Originally Posted by poisx7
thats the right line to reach both side of the bank.
Originally Posted by ljmushock
i wouldnt put that crap in my car if acura told me to. the only thing ur CL needs is good oil and a good filter, additives are crap
Seafoam is not some additive crap. It does really work in older high mile engines. It does clean out the block. I've seen it work on many older cars.
is that normal??
Originally Posted by m733l
did you let it sit for 15min then start it up? that's the same line i used and after the 15min soak i fired it up and i had white smoke for blocks
while I put the seafoam in there, engine had been off two times 0 o 0;;
I restart to apply the rest of the seafoam..
and sit for 20 mins after I put seafoam in...
when I started the engine first time. it's a little bit rough to start it..
then I wait for five mins.. no smoke at all @@"
should I do it again.? or just wait till this summer ends to do it one more time?
did you just start the car up for 20 min or drive it for 20 min?
also, at the end did you start it and let it idle for 5 min or you took it out on the "spirited" run?
I just stay there for 20 mins to let it gets warm... it matters?
Originally Posted by qwpobird
should I drive out for a while at the beginning???
word
Drive the car to warm the engine.
Park the car and with the motor running let the vac line suck in a whole can of seafoam slowly.
shut car off for 15 min.
Start car and take for a spirited drive to burn it all out.
it should smoke.
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
