Jetta Almost......
I'm in
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
The other night I was simply minding my own business driving a tad bit aggresive.
I pull up to this light and I take off to 50 then slow down to 40mph.....While I did this the modded Jetta, probably 00-02, exhaust, tach, air intake......so he passes me really fast. Then we meet up at the following light and I'm behind him light turns green he takes off I follow I switch lanes to pass him and he (I assume) floors it. So were neck and neck and I DID NOT pass him till 120! That supprise me for a Jetta.....Im driving an 04' NBP Apsec 6mt and this happened with VSA on....
Also when I hit 125 that he backed off.....
noodles tastes good.
For a few hundred bucks those jettas can be modded with an extra 40hp/tq - then they will eat the TSX for lunch, dinner and breakfast. I bet he was modded. Either way, stock 1.8 jettas are no slouch vs the TSX.
hey i had to reply with this
Stock Jetta 1.8t 02-04 will run 15.1-15.3
Add a Chip, Downpipe, Forge 006 Diverter Valve
and your looking at high 13's-low 14's if you know how to drive
add a turboback instead of just the downpipe, and its in high 13's
you can get them into the 13s for less then 1000 bucks
Pres TeamMidnightInvasion
less than 1000 dollars and get a jetta into the 13's
i donno if someone can get a jetta into 13 secs for under 1000. Tf this was possible then there be alot more people buying jettas, thats for sure.
![Sure](https://acurazine.com/forums/images/smilies/sure.gif)
vwvortex.com
i spent 300 dollar on a chip and 500 dollar on a 2.5" turboback and then a hks bov and i pulled 14.2 ... i have slips ... this was a tiptronic car too ...
Tristate ViP Crew
The 1.8T is an ok car but like Hurley said you have to make it quick, that factory turbo aint all that but once it's manipulated it is pretty good.
yep . hey the factory turbo sucks .. its half the size of a dollar bill
but with just a chip you can boost it to 23/24psi no problem and it holds it allright
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
kixo
09-01-2015 06:27 AM
