trying to jack up the car from front in order to place jack stands at factory recommended behind front wheel points, and wondering where I can place car jack. I've seen several threads but still getting mixed senses so took a picture to ask if any of these are good place...
thanks in advance. 2001 Acura CL Type S. Front Under.
^ The 'front jacking bracket'; 'A', as shown in post #2 on the thread below, is illustrated in step #4.
You also have it as 'A' in your picture above.
Center the plate of the hydraulic jack on that 'point' and it will lift the car centrally, allowing placement of jack stands at front support point(s) 'B' illustrated in step #1 of the same illustration. Jack/lift points on the CL? - AcuraZine - Acura Enthusiast Community
I lift using my floor jack on position A but I place my jack stands on the scissor lift points behind the front wheels. There's a metal plate at that point. you can see it in your picture.
