J37 Intake Manifold IMRC
Was wondering if anybody who has successfully gotten this working could help me out with getting this working.
Looking over the diagram I am having some trouble interpreting it. The motor output +/- are easy enough. Same with the ground. Did you guys just wire up these three wires to the J37 manifold IMRC actuator from the IRMC unit?
Also, where did you get the connector that goes onto the J37 IMRC actuator?
Were you guys able to test out the IRMC to see if it worked?
Whats up with RDX owners?
There are only two wire you need to worry about. Positive and ground. I couldnt locate the specific connector for it so I just used two wires, spade connectors, wire loom, electrical tape, and a small ball joint boot.
75mm
rcs86
08-02-2016 06:52 PM
