??J32A3 PISTONS FIT J32A2/J35A4 hybrid?? 12:1 Compression?
Will J32A3 pistons Fit in the J32A2 ?? If it does, anyone know how much compression will it make with J35A4 Block internals like Crankshaft and rods..Im guessing 12:1 if this is correct please confirm!!
Thank you !!
p.s.
please dont send me old forum links.
Thank you !!
p.s.
Yes high compression all stock motor (no boost or nitrous) at least 12:1 ration or even more!!
keep in mind i have j35a4 internals in j32a2 block..not looking for anything expensive like forged just cast metal oem like.
these are the pistons im talking about will these fit??? My j32a2 with j35a4 internals will i have valve clearance?? These are j32a3 pistons
https://www.partsology.com/piston-se...SABEgK1F_D_BwE
Also are the pistons above the same as the ones in the bottom offerd by powerrevracing but more pricey??? The bottome ones will fit j32a2 no problem or modification needed..thank you for your vital help friend!!!
P2R DNJ High Compression J Series 89mm Piston Set
MY MISTAKE I SENT YOU THE J35A8 PISTONS LINK !!
THESE ARE THE CORRECT ONES J32A3 PISTONS BELOW!! I APOLOGIZE!!!
https://www.partsology.com/piston-se...SABEgLsYfD_BwE
01CLinprocess
01-14-2017 04:00 PM
DEPTLS
12-19-2010 05:55 PM
2N10s
07-22-2010 02:15 PM
