Interior lights???
Interior lights???
What lights did anyone use to replace these weak ass stock ones. i want to know about what the visor lights are, the lights above the rearview mirror and the dome light in the middle. thanks..
For the dome light, I installed a PIAA T-6 bulb. It's not as big as the stock bulb but fits just fine. And for the door lights, reading lights, trunk light, and rear plate light, I used the PIAA 19169 bulbs. The only interior light that I have never been able to replace is the visor/vanity mirror lights. Those things are so small that I'm guessing they'll never make PIAA's in that size. I know others have used other bulbs like M-4 and M-6 I think instead of PIAA's so you could do a search for lights or check out Chod's excellent FAQ, link below.
http://www.geocities.com/~gamesmgr/chod/acura/
He's got basically everything you'll ever need to know covered in that.
Here's the section from Chod's FAQ that you need:
Recommended bulbs for internal lights?
Example sets used by people:
Dome light: Polarg M16 or Minimax bulb (Part no: MX-3175)
Polarg M4: Trunk lights, license plate lights
Polarg M4 or PIAA 69 for Door Lamps and Map Lights,
Reverse Lamp: M2 or M13 (M13 is dual-element so brighter but more expensive)
Turn signals (1157 type bulbs): Polarg M12
Originally posted by Scooter
here...some good shots of interior bulbs...
http://www.acura-cl.com/forums/showt...ghlight=lights
Originally posted by AztecRol
DANG Scooter, as many times as you and I have been through this, you would think some of these people would learn something!!!! The link Scooter attached has all the info you will need!!!!!! Good Luck!!!!
handsom-hustla
11-13-2015 05:04 PM
oyayjoe
09-12-2015 04:40 PM
