Intercooled SC Dyno
#161
not to be a downer...
Originally Posted by importtuner
Wow!!! Congrats; you are officially a M5 and Vette Killer!! Now lets get them E55's; damn thing's a beast!! Show the world what a Honda can do!!!!!
-Justin
-Justin
cuz the car is impressive as hell, but I doubt he's an M5 and vette killer... although his HP is great, the torque is still low, and then there's still the jump. From a dig, the vette/M5 should still win. This is by no means a knock, just keeping it real.
Then again... DAMN... that is impressive. =) Wish I could run you... would be fun.
#162
hey allmotor...
Originally Posted by allmotor_2000
Las Vegas this weekend and Phoenix on Thursday... my usual trips are to Asia - let me see how I can work Atlanta into the picture!!
Are you in Vegas tonight? I'm in Vegas on a confernece, and if you're around my buddy has a CL-s too... would be cool to hookup and see your turbo. Lemme know.... I'll send you PM.
#163
i bet it is a (current) M5 and C5 killer.
my car runs nearly as quick as either of those, and steve has over 60 more whp and wtq.
#164
Well, I'm going by the projected times. If he's runnning 12.9 @ 110, that might be a C5 edger... I wouldn't say "killer" per say. The new M5 is 500/500 I thought... that will be balls to the wall. Current M5 shouldn't be much of a problem, but i wonder if he'll have it with the launch. If he can get 60 ft down to about 2.0, then it should be close.
Oh well, run what you brung. If he turns anywhere in the 12's, that's damn impressive.
Oh, and MattG... what the hell? I thought your car was NA... you're running with C5's and M5's now? I didn't know the CL-S was such a powerful FWD dragster!
P.S. -- Nevermind... just saw the N20....
#165
i drilled a little hole in that icebox you sold me.
13.2 @ 105 on 18" street tires, 90 degree weather.
from 50 - 110 i think i could do nicely against a (stock) M3, M5 or C5.
#166
Hmm...
I bet he doesn't have 60 wtq more... N20 makes really good torque. You might be close actually, if you're about 230 fwhp, and squeeze 75 shot, you should be over 300 ft-lb....
#167
my dyno from unichip was 300 whp and 253 wtq.
i need to get on a dyno jet though.
#168
I have to agree about getting out of the hole; I will have a much more difficult time. But being able to trap 3+ MPH higher I should be able to run them down. That is provided I don't completely botch the launch.
#169
If he is making about 230 WHP he then is making about 190 - 200 WTQ. A 75 hot would give him about 60 WTQ more. That, added to 190 - 200, equals about 250 - 260 WTQ. That is exactly where his dyno showed him at.
#170
#171
Originally Posted by scalbert
That is something else I am working on. I have to mill out one more piece and I should have the front and rear components completed to help get the power put down.
#172
Originally Posted by av6ent
Driveshaft?
#173
Nice.
But how is the driveshaft durability on CLS with blown power as yours?
I hear everywhere that Mustang and LS1 people snap stock driveshaft in half when they add power, or is it only involves RWD vehicles?
#176
They swap the "axle/driveshaft" assembly. Basically they replace the axles.
A conventional driveshaft like you would find on a RWD car is totally different than one for a FWD car.
FWD:
Connects the transmission (mounted beneath and slightly behind the engine) to the front wheels
RWD:
Connects the transmission (mounted behind the engine) to the rear differential which connects to the rear axles, which connects to the rear wheels.
FWD:
RWD:
#178
#179
So far so good but currently the tires give way first.. If I were to run slicks and a good suspension set up for optimal launching, who knows if they or something else might give. I guess we'll have to see though.
I would think as long as you don't leave the line with 100% traction you'd be okay. Drag radials would really help... slicks you might be asking for a new pressure plate and new axles. And I think the axles are like $800 a piece
#180
13.68 @ 102.56
Killer, I wouldn't say either. But it should be able to run them two down. However, about the torque being low?? 310 lb/ft at the wheels is too low when compared to those two vehicles?? It makes as much, if not more, torque than those two do all while making more power at the wheels than the C5 does at the crank.
#183
Originally Posted by mrsteve
I'd say the Nitto's or the BFGs. Leaning more towards the BFGs.
And I'd get 17x8 light forged rims (14-17# each) with 245/40/17 front tires where Nitto are available.
#184
I'm considering the below from Tirerack for strip use. Inexpensive and should do the job required. The rims are 17.0 lbs.
225/45R17 BFGoodrich g-Force T/A Drag Radial Blackwall
for 2003 Acura 3.2CL-S In Stock $128.00 $256.00
17x7 Kazera KZ-V Silver w/Machined Lip
for 2003 Acura 3.2CL-S In Stock $129.00 $258.00
#185
Good price but I thought you wanna go wider for traction.
and rims look the same as Serge getting but @ 15.4 lbs and wider:
17x8 Kosei K1 TS
Light Grey Painted $239 each
245/45/17 Nitto 555R $158.40 each
Anyway, better then you stock ones
17x8 Kosei K1 TS
#186
Actually I haven't decided what I will first try. I might try the strip with the street tires and just the suspension set up. Then try later with DR's to see how much better they perform.
#189
Originally Posted by pimpinTL02
how come launch is a problem? please educate me? traction control all this stuff
The 6MT doesn't have VSA or any sort of electronic traction control. The 5AT would be hampered by the VSA as it would always be active killing power more than what you could control yourself.
#190
Blown is Best
Is it worth considering going with a smaller diameter setup to raise the effective gear ratio? Not sure what gear and what part of the RPM range you're ending up in at the end of the 1/4. Launch will still be an issue but possibly keep the motor in the sweet spot?
#191
It would depend on how much smaller you went. Without the blower or even with the base kit a shift to 4th will be required regardless. If that is the case then shortening the overall gearing might help times.
At my current point, if I lowered it too much, a shift to fith may be required which would hurt the times.
I would really have to run the numbers and see where the advantage is and where it would be a detriment.
#195
TQ > MPG
4th should be good for at least 125mph, assuming 225/45/17's + OE gear ratios (1.25 4th & 3.286 axle) + redline of 7200rpm.
The BFG G-force 225/45/17's are only .5" shorter than stock, so they are pretty close.
I plan on going with a set of used 01 CL-S wheels and I can get the 225 BFG's for about $125 at the local discount tire, including install.
D-Rob
62
01-05-2016 11:44 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
accordy2g
12-25-2002 03:19 PM
