Installed new Alpha Werks Header
As I mentioned in a previous thread I ordered a new type of header for my 01 CLS auto trans. Last night I installed myself and here's how it went.
I used new Acura Factory gaskets instead of the aftermarket gaskets that came with the new headers. The front headers slid right on. When I went to place the rear header on, the bolts did not line up. The header needed some enlargement of the holes which I expected from reading previous installs of other's aftermarket non CT headers. This did not take long and was not very hard to do. After doing this I ran into a problem that I did not expect. The rear header extended down and ended directly into the drive axle shaft. There was no way the the down pipe was going to connect to the header with the drive axle directly in the way.
After trying to figure out why, I discover a possible mistake made by Alpha Werks. If you review the pics I posted on the other thread the header sitting on the box has a Alpha Werks engraved name plate on the center tube. When I installed I assumed that this was the front header because you cannot see the rear header very well if at all and it made sense to me that the nameplate was for the front to be seen. Well I switched the front and rear around and found that I had them installed backwards.
With them now installed corrrectly the downpipe bolted on without any problems and I tigthen and checked everything out. After rechecking all fitting and nuts and bolts I started the car to check for leaks and there were none. I also was possibly expecting the Check engine light to come on but it did not and I was very glad. Other than the hole enlargement and mix up of front and rear it all went very smoothly. The total time to install was about 3 hours and this includes the reverse install of front and rear.
There is no unpleasent noise and the car sounds great with my Neuspeed Cat Back system.
It snowed here last night and I drove the car back home about 20miles from where I was. I did not have a lot of time to tell a diffrence yet but did notice that the car pulled a lot stronger in the 6000RPM range and seems to keep pulling. The responce is quicker and at the V Tec engagement it spun so fast in SS automode I twice hit the limiter in 2nd gear before I could change. I've not done that too much before recently and I did it 2 times last night. I hate when that happens.
The current engine mods to my car are Injen I/T, Alpha Werks Headers, Neuspeed Cat back exhaust. I plan to Dyno the car on SAT. Anybody know what the average Dyno Jet read has been for the CLS auto with I/H/ and Cat Back have been ?
I next plan to get a high flow Cat Converter, Crank Pulley UniChip, and the ZEX dry Nitrious kit. Will post Dyno Results and graph soon. I am very happy with my new header and have spent less than $1000 on all 3 engine Mods so far. My objective is $0 install cost by self installs and a very low dollar to HP cost ratio. I would give the Alpha Werks a good rating above all as a C/T cost alternative.
Jamie
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Jamie
Originally posted by Ray Khan
I assume since you made no reference to it, the 02 sensor bung was located in a good place. The OBx one puts the sensor almost right up against the tranny.
Originally posted by str8acura
how much did they cost? is alpha workks a reputable company?
-S namyaC-
Are these those headers that look really well made but have that whack J-pipe? By whack I mean the tube that comes from the rear header hits the other at a 90deg angle?
If so, I don't these will dyno as high as the Stone/OBX (of couse the Comptech too hehe).
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Originally posted by Nashua_Night_Hawk
you should have done a before dyno too!. How come you can judge gains otherwise?
I think to accurately judge I would personally ( my opinion) do stock, no I/ no Cat B,. 1st run stock CLS, 2nd run with Header. Prev experience is that sometimes combo of diff mods not good judge. I Agree that would tell before and after diffrence on my set up and car but not if C/T more power, Stone more power, Alpha Werks more power. 1 header may like C/T intake better, other may like Injen intake, other AEM and so on. I also have a diffrent Cat back than most. If this headers showed higher H/P increase than other that would not mean it was that header that was better, just combo. Maybe somone will order and do for you to see. Or get group to meet at Dyno and run 1 car and test all headers back to back.
Just my opinion from 200+ dyno runs on a built Kawi zx-9 I had.
Homeless
So, basically, we don't know a thing about these other than they are easily installed(versus some other brands folks have had issues with).
Still interested in seeing the dyno with the other mods...most guys here have intake atleast, so it's still plenty useful.
Originally posted by chris3240929
Still interested in seeing the dyno with the other mods...most guys here have intake atleast, so it's still plenty useful. [/B]
-S namyaC-
Originally posted by jgscott
Why don't you check it out and answer your "whack" question. I am not promoting, or selling anything, just sharing info of somethings I am trying..
http://www.acura-cl.com/forums/showt...hreadid=131913
Hey man, no need to get upset. These are not the ones I was talking about. If you had seem them, you'd know exactly what I was talking about and would prob make the same comment. These look just fine.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Beware of leakage
Since the design is a Comptech copy, I would expect the gains to be similar to Comptech's and the other clones. It is not like they are internally coated or have some unsual charateristic to make them perform better. They are just pipes in a certain design and as such will provide similar gains..
The difference may be in the quality compared to the other clones.; that will need to be seen. I seen no need for a before and after...
Originally posted by Chopper
Mine Do not.
Mine Do not.
well either you are lucky, or Ferizzo is unlucky. We had to drill out the back side header bolt holes a little on his as well. The O2 sensor was close enough to the tranny that the dealer bitched about it when he had his tranny replaced. They even said something like the wires to the 02 looked like they were fraying a little and wouldn't be covered under warranty because of the aftermarket headers. To me this is some bs excusefor the dealer since they probably bumped something in the tranny install/uninstall. Who knows. Good to hear your headers fit well.
Mine Do not.
Mine Do not.
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
